02-02-2015, 01:00 PM | #1 |
Tanzanite Blue II X5M Pilot
1035
Rep 2,017
Drives: M3, M4, X3 M40i, X5M
BBS LMS 18x9, 18x10
BBS LMS with Custom offsets built by Paul Erlich of ewheelworks.us. Brand new build, never mounted. Gorgeous!!! Currently wheel configuration; 18x9 et4 with 3" lips 18x10 et4 with 3.5" lips *This is an aggressive offset for most BMWs which may require stretched tires and/or fender modifications If the above offset is too aggressive for your purposes, the wheels can be professionally reconfigured at a minimal cost to accommodate your desired appearance and fitment. Please see options below Option 1 Purchase 2 new lips for the front and swap existing lips to the rear (The total charge for the new lips and professional reassembly would be $360) 18x8.5 et10 with 2.5" lip 18x9.5 et10 with 3.0" lip *this should fit most 5 6 7 8 and e30 M3 BMWs with minimal tire stretch and/or fender rolling Option 2 Face mounting using existing lips (This choice requires professional recoating - which can also be completed in the color of your choice for a total of $300) 18x9 et19 with 3.0" lip 18x10 et19 with 3.5" lip *This should fit most 5 6 7 8 and e30 M3 BMWs without having to use stretched tires or fender modification These are absolutely the most gorgeous BBS LM wheels ever built and are Paul Erlich's (ewheelworks.us) personal favorite that he has ever built to date. These were intended to go on my e34 540i/6 Msport. They have never been mounted. best response by text 336-413-3198 or email raceboy1963@aol.com Thanks for looking! Last edited by gixxerboy63; 03-06-2015 at 09:29 PM.. |
02-02-2015, 03:18 PM | #2 |
Rep 2,348
Drives: TT Flat Six
those are beautiful
02-12-2015, 08:57 PM | #3 |
1035
Rep 2,017
Thank you!
They need a new home where they can be seen and enjoyed. I no longer have a vehicle they will fit. :/ |
03-06-2015, 09:23 PM | #4 |
1035
Rep 2,017
New offset options!
BBS LMs 18"
Currently wheel configuration; 18x9 et4 with 3" lips 18x10 et4 with 3.5" lips This is an aggressive offset for most BMWs which may require stretched tires and/or fender modifications If the offset is too aggressive for your purposes, the wheels can be professionally reconfigured at a minimal cost to accommodate your desired appearance and fitment. Option 1 Purchase 2 new lips for the front and swap existing lips to the rear (The total charge for the new lips and professional reassembly would be $360) 18x8.5 et10 with 2.5" lip 18x9.5 et10 with 3.0" lip *this should fit most 5 6 7 8 and e30 M3 BMWs with minimal tire stretch and/or fender rolling Option 2 Face mounting using existing lips (This choice requires professional recoating - which can also be completed in the color of your choice for a total of $300) 18x9 et19 with 3.0" lip 18x10 et19 with 3.5" lip *This should fit most 5 6 7 8 and e30 M3 BMWs without having to use stretched tires or fender modification These are absolutely the most gorgeous BBS LM wheels ever built and are Paul Erlich's (ewheelworks.us) personal favorite that he has ever built to date. These were intended to go on my e34 540i/6 Msport. They have never been mounted. |
06-17-2015, 01:43 PM | #5 |
1035
Rep 2,017
To the top!
