      01-02-2018, 12:09 PM   #1
Frenchies_M5
Drives: BMW M5 F10
Umnitza LED Headlight coding
Hey guys, I was wondering if anyone knows what lines need to be coded for the umnitza led F10 M5 headlights.
just got them installed and its full of errors that need to be coded out.
was also wondering did you guys get so many error codes? The angel eyes, turning signals not working without the coding? (just want to make sure that its the coding that is needed and that the headlights are not defective!)
      01-02-2018, 05:10 PM   #2
SapphireM5
SapphireM5's Avatar
711
They are defective and should not have them installed on your car. Ill do you a favor and take them off of your hands. Ha! J/K, you just need the coding to fix that. Few members on here will do it for you if you do not have anyone locally. Check the thread for the Umnitza lights, a few guys who do the coding posted up in there. GL! I bet they look great.
      01-05-2018, 04:48 AM   #3
sonnenschein3000
Drives: 2015 M5 (F10 LCI)
Do these still need additional wiring like the OE upgrade requires, or is it plug and play into the existing xenon wiring?
      01-05-2018, 06:53 AM   #4
Frenchies_M5
Drives: BMW M5 F10
It's plug and play. Got the coding done and all the errors went away but had to reconnect the headlights first
2013 BMW M5 Silverstone Metallic/ Black Interior
Executive Package - Driver Assistance Package- Bang and Olufsen
      06-18-2018, 03:52 PM   #5
MilosM5
Drives: M5
Hi BMWfan95 I have same issue with Umnitza headlights on my Bmw M5 F10. First set of Umnitza headlights didn’t work then I replaced them and last Saturday received a new set of Umnitza headlights. Problems again ! Driver side daytime running lights (angel eyes) not working.
Problem with passenger side headlight is turn signal and cornering light not working.
How did you fix this problems with coding ? Is your headlights working good now ? And who did coding on your vehicle ?
Thanks
      06-29-2018, 02:28 PM   #6
movemnt Inc
Drives: 2012 F10 M5
Hey by any chance after the install of the led headlights your radio reception wasn’t working well? Cause I am currently having this issue and the radio reception is horrible only when the lights are turned on and when it’s not it’s clear as day... shop doesn’t know what is the problem here
      04-06-2019, 09:38 AM   #7
boomerang.e92
boomerang.e92's Avatar
Drives: E92 M3
Does anyone have a solution to a cornering issue?
      07-15-2019, 11:34 PM   #8
Carlezzy
Drives: BMW F30
I might be able to help
Those are the aftermarket ones right
No modules just lights?
      07-17-2019, 07:51 AM   #9
boomerang.e92
Drives: E92 M3
Ya. Plug and play
      06-28-2020, 07:15 PM   #10
skybmw
Drives: Bmw m5
Hey did you fix your problem? I have the same problem and i cant find a way to fix it. Is it the coding? Or the headlight?
      07-02-2020, 09:37 PM   #11
Plng777
Drives: Bmw m5
https://f10.m5post.com/forums/showthread.php?t=1732222
      11-01-2021, 09:15 AM   #12
jellogwapo
Drives: BMW F10
Umnitza headlights
Hi, I have the same errors you had on the Umnitza headlights, may I know where you had your coding done, or which ones?
thanks heaps!!
