      04-11-2023, 08:57 AM   #1
D4T
Drives: 2013 F10 M5 LCI
Question Datalog analysis - does this look normal?
Hi all,
Just wanted to check something as I just took a couple of datalogs from my car and I'm not sure I'm happy with how the log looks but could do with some other opinions.
I wasn't concerned with how the car was running at all until I did some logging and looked more carefully at some old datalogs I had saved.
Essentially though to me it looks like it's pulling lots of timing across all cylinders - I don't think this is "normal" is it?
I've also noticed it pull timing at idle (only like -0.5 to 1 degree) which seems weird and some knock events detected when I'm off the throttle. I assume that any knock events aren't normal or are some to expected here and there due to noisy engines?
Datazap link
Thank in advance,
D4T
      04-11-2023, 02:23 PM   #2
fstm5
fstm5's Avatar
146
Originally Posted by D4T View Post
Hi all,
Datazap link
Thank in advance,
D4T
Need more info, tune, fuel type etc
Only pay attention to knock if it’s pulling timing, or else it’s most likely false knock
      04-11-2023, 02:27 PM   #3
D4T
I’m running the Stage 1 91 octane BM3 tune on UK 99 RON fuel as I wanted to leave some headway. The car made 699bhp on a local dyno and as I said I’ve never been that concerned until I noticed lots of timing pull.
      04-11-2023, 07:34 PM   #4
fstm5
fstm5's Avatar
146
I’m no professional but your timing seems ok, a few degrees here and there from my understsnd isn’t really an issue as there’s a lot of reasons why timing can be pulled, fuel etc. I don’t see any knock but again it’s difficult to look at the log on an iPhone. Timing is great only in some RPMS it’s being pulled.
