05-22-2013, 08:54 AM | #1 |
Rep 22
Battery Discharge
Hey all,
I am getting the warning "Battery Discharge while Stopped: All electrical devices temporarily switched off". I have read all of the other threads on this and I don't have anything plugged, lock the car and I have a battery tender. This usually happens after it sits overnight. After I start it in the morning, shut it off and then restart it the message clears and everything is fine until the next morning. Even for 8-9 hours while I am at work. I come home, put the battery tender on and the message appears in the morning. I don't drive a lot (Sept. 12 delivery with 2800 miles on the clock) but the battery tender should fix this right? Dealer can't get me in for 10 days. |
05-22-2013, 10:04 AM | #2 |
Rep 2,245
Do you turn your accessories off after turning the engine off? I was told during delivery to hit the On/OFF button twice when leaving the car. Once to turn off the engine, the second time to turn off the ignition and accessories.
I think some have argued that locking the door does the same thing, throwing the car in park and turning accessories off, but Ive already gotten into the habit of doing this. For therecord, the manual states this as well.
2016 991.1 911 Carrera GTS
05-22-2013, 04:18 PM | #5 | |
Rep 46
05-22-2013, 08:43 PM | #6 |
Rep 79
Couple of things.
Some guys had their cars sit during the winter at the port awaiting delivery for a long time. They have seen lame battery performance and have forced the dealer to replace. I actually did not accept delivery until the battery was tested passed and a print out signed. So far, so good. Also the battery only charges during certain times like when the car is at cruising speeds. What happens over time if you only drive it for short bursts, the battery will eventually croak. Lastly anything USB will not shut off when you shut off the car. It will always stay on so if you have a mem stick or phone charger plugged in there it will slowly drain and kill the battery. With any BMW you will likely need a battery minder so if you don't drive a lot, or not far every time, even in the summer you may need to plug it in. I would definitely have the dealer look at it and if you suspect it is a bad battery insist it is replaced. Heads up, the dealer will likely go out of their way not to replace it. Best luck |
05-22-2013, 09:39 PM | #7 |
Rep 22
When I first had the car I accidentally did not push the button twice but this occurred maybe three times. No radar detector ever and only the iPhone when started. Hard to say I abused the battery. We will see how good my deler is I guess.
05-23-2013, 08:33 PM | #8 |
Rep 5
Battery discharge
Hi, did u install any camera in your car? It will still recorded moving objects when it's in off mode. Unless u deactivate the motion sensor in the camera.
05-24-2013, 12:21 PM | #10 | |
Rep 1,095
Drives: 09 SC E90 M3 / 13 F10 M5
05-24-2013, 02:47 PM | #11 |
Knight Commander
559
Rep 5,948
I had this issue with my Lexus a few years ago. Turned out the cars electronics were fine, but I had an aftermarket HID foglight kit which was draining power from the battery even when the car and lights were off. Lexus diagnosed the car was draining electricity when switched off. I disconnected the accessories one by one - radar, laser jammer, GPS tracker, fog lights to identify issue. fortunately the fog lights were my second guess after the GPS tracker so it didn't take long.
Also whenever the battery gets fully drained it damages the battery. If its happened 2-3 times you may need a new battery. I was lucky that Lexus gave me three free batteries in a row because they didn't know it was caused by my accessory.
2022 Mercedes-Benz EQS 580
