      02-16-2018, 10:45 AM   #1
V8munro
V8munro's Avatar
Drives: F10 M5 Sakhir Orange
Stock turbo stock engine vbox times
Just had the new v2 jb4 fitted to my car and went out doing some vbox data, i got a 100-200 kph in 5.3 and 60-130mph in 6.2 both verified. Car has no cats, eventuri intakes with their new filter, evolve flash, 100% meth with cm10 nozzles. I was pretty impressed with this and think its a good time for the mods it has? Has anyone got much faster on stock turbos?
F10 M5 2013 Sakhir
Eventuri Intakes, Supersprint backboxes, catless downpipes, ssp spec r, ECU flash, JB4 BCM and BMS dual CM10 meth
Insta: Tommy_turb0
JK-M561.00
      02-18-2018, 06:51 AM   #2
V8munro
V8munro's Avatar
Got the times down again, no idea what sort of power this would be though? Maybe 700whp?
F10 M5 2013 Sakhir
Insta: Tommy_turb0
      02-18-2018, 02:43 PM   #3
bquicksilver
bquicksilver's Avatar
Drives: 2014 F10 - Alpine White CP
Thanks for sharing! What gear do you guys start a 60 roll in? 3rd?
      02-18-2018, 06:28 PM   #4
allmotor_2000
1087
Drives: 2018 RS3, 991 Turbo
This is very quick!! Probably closer to 750-770whp.
Very impressive for what you have on the car.
What map/boost?
      02-19-2018, 04:51 AM   #5
V8munro
V8munro's Avatar
I started my roll in 3rd as i dont know the correct shift point for 2nd gear when doing this, i assume 6500 is too late as its a shift after 62mph. Boost was peaking at 27psi using map 8 and 60additive.
F10 M5 2013 Sakhir
Insta: Tommy_turb0
      02-19-2018, 04:55 AM   #6
V8munro
V8munro's Avatar
Id be over the moon with 750whp
F10 M5 2013 Sakhir
Insta: Tommy_turb0
      02-19-2018, 04:58 AM   #7
Hotsawwce
Drives: M6
The intakes probably added 80whp
      02-19-2018, 05:02 AM   #8
V8munro
V8munro's Avatar
I havnt done much testing with stock intakes to see if theres a difference. I got these mainly because my stock boxes were butchered on my first m5 and i like the look and sound. I like to think they help but not massive amounts.
F10 M5 2013 Sakhir
Insta: Tommy_turb0
      02-19-2018, 08:00 AM   #9
allmotor_2000
1087
Pretty sure it’s in that range. Maybe the conditions are different when you will dyno but you need 750+ to get those times!
      02-19-2018, 08:20 AM   #10
allmotor_2000
1087
On stock turbos you can do 3-4 or even just a 4th gear pull (no shift) as it spools up in time.
      04-18-2018, 03:39 PM   #11
V8munro
V8munro's Avatar
Just got a 4.9 100-200 and a 5.8 60-130 still stock block and turbos
F10 M5 2013 Sakhir
Insta: Tommy_turb0
      04-18-2018, 04:10 PM   #12
apexlocator
Drives: 2014 M5
Very impressive
      04-18-2018, 06:13 PM   #13
V8munro
V8munro's Avatar
Thanks mate, was quite a good adrenaline buzz haha
F10 M5 2013 Sakhir
Insta: Tommy_turb0
      04-19-2018, 01:52 AM   #14
Mr. M6
Mr. M6's Avatar
149
Drives: M6
2014 BMW M6 F06  [9.25]
thats very good numbers out there,
i will do flash OTS stage 2 today and i will check vbox later, but the weather here very hot.
      04-19-2018, 12:53 PM   #15
Mr_M5Guy
Drives: e60 M5
Stock clutch also? And do you have jb4 controlling the meth?
      04-19-2018, 01:23 PM   #16
V8munro
V8munro's Avatar
No spp spec r and yes jb4 controls meth
F10 M5 2013 Sakhir
Insta: Tommy_turb0
