08-04-2023, 03:12 PM | #1 |
Rep 471
S63TU Injector Replacement
Blackstone reported a lot of fuel in the oil. Did the oil change at 4,000 miles and 8 month spread. Took the car to the dealer as there is warranty on the injectors (10 years / 120,000miles). They didn't find any codes and no oil in the current oil (of course new oil is only 100 miles old, old oil was the one tested...) and because the car is tuned (BM3 stage 1) they said even if they bench test the injectors BMW won't cover them. So I will go ahead and buy a new set and get them installed. Don't want to risk anything. Does anyone have any experience with the 3 options available? One is Bosch vs Genuine (which I thought was the same anyway except 3 times the price but same part number). Is there is a way to see if the current ones are EU5 or EU6 on the car by using Protool or Bimmercode? Thank you
08-04-2023, 03:49 PM | #2 |
Fueled by Recycled Dinosaurs!
630
Rep 1,171
Drives: F06 M6
I have not tried this myself but I have read where others used a borescope camera and was able to read the print of the injector. The best method is with BMW's ISTA. If you are an android user check this out. https://f10.m5post.com/forums/showthread.php?t=2003759
When you buy the injectors get the package that has the decoupling rings.
08-04-2023, 07:58 PM | #3 |
Rep 538
Did the oil smell like gas?
Johnbrown_bimmer0.00 |
08-04-2023, 09:17 PM | #4 |
Rep 538
08-04-2023, 10:44 PM | #5 |
630
Rep 1,171
Drives: F06 M6
Could be blow-by, basically piston rings are not holding everything in the cylinder like it should. A leakdown test could tell you if you are are not holding pressure.
M5Rick60091.50 |
08-05-2023, 09:56 AM | #7 |
630
Rep 1,171
Drives: F06 M6
I am not familiar with it but I will definitely check it out.
M5Rick60091.50 |
08-05-2023, 10:59 AM | #8 |
Rep 19,560
TinCanSailor629.50 |
08-05-2023, 11:08 AM | #9 | |
630
Rep 1,171
Drives: F06 M6
I'll see if I can get these from costco. Speaking of costco they are a top tier gas station, at least in my area. If I remember correctly they have 3 to 5 fuel additives in their Petrol.
M5Rick60091.50 |
08-05-2023, 12:16 PM | #10 | |
Rep 19,560
I use a new fuel, Texaco Supreme 99 Performance at 99RON with no added ethanol at the last test on it. This fuel is only at selected Texaco stations one which is 3 miles from me and ethanol free to which I add the portion of Redex when I fill up. It's especially good before the yearly engine test as its claimed to reduce emissions as well as protecting the fuel system and injectors also cleaning up burnt deposit stains in the engine where present. |
08-05-2023, 12:23 PM | #11 | |
630
Rep 1,171
Drives: F06 M6
M5Rick60091.50 |
08-05-2023, 12:37 PM | #12 |
Rep 538
If you want a good injector cleaner in the US go with Berryman B12 Injector Cleaner. Works great and low price.
08-05-2023, 01:01 PM | #13 |
Rep 19,560
I think your gas stations there are Chevron Texaco who merged and you have the Techron additive in all of the Texaco gas.
08-05-2023, 01:22 PM | #14 |
630
Rep 1,171
Drives: F06 M6
I have heard of them before and it was all positive news.
08-06-2023, 03:29 PM | #15 |
German car enthusiast
Rep 20
Mine does too sometimes, and Blackstone showed no fuel in the oil. But I am curious as to where the gasoline smell comes from, other than, of course, just further refining oil until gasoline results. A friends '16 pure metal with 8k miles on it also smells like fuel in the oil cap. That's small sample but does anyone's oil cap *not* smell a little like gasoline?
08-07-2023, 11:54 AM | #17 |
630
Rep 1,171
Drives: F06 M6
