07-21-2015, 09:42 PM | #1 |
Rep 16
Turner 20mm spacers and extended wheel bolts
$80 plus shipping Turner BMW 20mm Wheel Spacers - E70/E71, F02, F06, F07, F10, F12/F13, F22, F25, F3X, F8X M3/M4 (Pair) View more product information 20MM (.79 inch) Wheel Spacers with extended wheel bolts for BMW E70 X5M, E71 X6/X6M, F02, F10, F13, F25 Wheel spacers are the ideal solution to resolve a number of fitment and aesthetic problems. A spacer fits between the wheel and the hub assembly. The wheel will be pushed further outboard by the thickness of the spacer. Spacers allow you to correct wheel offset issues when the wheel is too 'tucked in' to the bodywork, clear the wheel from contact with the suspension or inner bodywork, clear larger brakes, improve handling and stability by increasing track width, or simply to get the right look and stance. Our wheel spacers are compatible with almost any type of BMW wheel and are a direct fit to the wheel hub (see below for any fitment notes). Longer wheel bolts or wheel studs are required. These latest generation of the Turner Motorsport Wheel Spacers represent a total redesign of the wheel spacer concept - a ground-up, clean sheet design based on our years of BMW service and motorsports. We took everything we have learned from our service technicians, customers, and race team crew and built the spacer to beat all spacers. We've been in the BMW wheel spacer business probably longer than anybody and when it came time to make our own spacers, a basic spacer design just wouldn't do. We had to make a spacer that is light weight (for lower unsprung mass), has a tough and durable coating to last through our New England winters, is easily removed (your mechanic will thank you), and is precisely engineered and manufactured for a proper fit on the hub and in the wheel. You won't find a better engineered wheel spacer on the market! Turner Wheel Spacer Features + hub-centric design with hub-centric lip + precise tolerance fitment thanks to CAD process and CNC mill machine + aerospace grade aluminum – light weight but very strong with a high resistance to corrosion + additional military-spec hardcoat for further corrosion resistance + innovative Quick Release pockets for easy removal (better than a chamfered back edge) + laser engraved size and part number for easy identification + stealthy anthracite or black color + Turner Motorsport track and street tested! + Made in the USA Wheel Spacer Tech & FAQ Important Note: It is vital that you measure the depth of your hub lip. The depth of the lip must not exceed the thickness of the spacer. This is critical on newer chassis cars that have deeper hubs than older models. For examples and tips on measuring, check out our How To Measure for Spacers page. Wheel Spacer Encyclopedia - everything you wanted to know Spacer Specs bolt pattern: 5 x 120 center bore: 72.6mm hubcentric? yes wheel pad size: normal Extended Wheel Bolts Required for all BMW wheel spacers is a set of longer wheel bolts or wheel studs. Spacers cannot be used with stock bolts. Our extended lug bolts are a very high quality and high grade steel lug bolt (grade 10.9). A black zinc coating will maintain a factory BMW appearance and provide long-lasting corrosion protection. Zinc finishes are designed to withstand 700 hours of salt spray testing. This item fits the following BMWs: Front or Rear 2014+ F22 BMW 228i 228iX M235i M235iX 2012+ F30 BMW 320i 320iX 328i 328iX 335i 335iX - Sedan 2012+ F31 BMW 328i 328iX - Wagon 2014+ F34 BMW 328i 328iX 335iX - Gran Turismo 2014+ F32 BMW 428i 428iX 435i 435iX - Coupe 2014+ F33 BMW 428i 428iX 435i 435iX - Convertible 2014+ F36 BMW 428i 428iX 435i 435iX - Gran Coupe 2015+ F80 BMW M3 2015+ F82 BMW M4 2010+ F07 BMW 535i GT, 535i xDrive GT, 550i GT, 550i xDrive GT 2011+ F10 BMW 528i 528i xDrive 535i 535i xDrive 535d 535d xDrive 550i 550i xDrive M5 2012+ F12 BMW 640i 640i xDrive 650i 650i xDrive M6 2013+ F06 BMW 640i Gran Coupe 640i xDrive Gran Coupe 650i Gran Coupe 650i xDrive Gran Coupe M6 Gran Coupe 2009+ F01 BMW 740i 740li 750i 750li 750i xDrive 750li xDrive 760li 2011+ F25 BMW X3 xDrive28i X3 xDrive35i Rear Only 2007-2013 E70 BMW X5M 2007-2014 E71 BMW X6 xDrive35i X6 xDrive50i X6M Part #: TWH9905020-X Regular Price:*$97.95 (USD) longer wheel bolts (TWH9961A50 x 10), Add $42.50 (USD) |
