      07-21-2014, 11:32 AM   #1
wrsbmw
wrsbmw's Avatar
108
Drives: 2018 Ferrari 488 Spider
Engine light with no status indication
Noticed the engine light was staying on this morning but there are no status warnings listed. Called the dealership. Anyone else seen this? Wondering if it's related to the new parts. Pretty sure it just showed up this morning since it's next to the DSC light and I have been switching that on and off and hence would be looking in that direction before today.
      07-21-2014, 01:52 PM   #2
Spinny02
Spinny02's Avatar
Keep us posted!
      07-21-2014, 09:02 PM   #3
wrsbmw
wrsbmw's Avatar
108
It went away but this evening when I started it up, it stopped and when I restarted it, it was in limp mode, drive train malfunction. So I drove to Torchy's in limp mode, no big deal around town and went in to get some tacos. Came out and it was fine. I suppose this probably has something to do with the ECU getting used to whatever DTronics is doing to the car. It's running OK now and it was when the engine light was on. SA said if the engine light cleared not to worry about it, it can even be a gas cap not on any good. I checked that.
      07-21-2014, 09:10 PM   #4
Spinny02
Spinny02's Avatar
This is not the norm. I would call dinan directly. Could be unrelated all together but the timing would point out otherwise.
      07-21-2014, 09:30 PM   #5
wrsbmw
wrsbmw's Avatar
108
OK, I may do it, it can't hurt to get their opinion.
      07-22-2014, 07:25 AM   #6
JPMD
Drives: 2014 BMW M5
Yes please keep us posted on this. Thanks
      07-22-2014, 10:59 AM   #7
EuroKar
You should have someone scan the control modules regardless if the light went away.
There is a code stored that created your engine to go into "limp mode".
That is not good my friend.
It may happen again. Better get it scanned before something bad does happen.
      07-22-2014, 11:51 AM   #8
Spinny02
Spinny02's Avatar
+1
      07-23-2014, 08:38 AM   #9
wrsbmw
wrsbmw's Avatar
108
Car is in the shop and Dinan is going to work with the BMW tech here to get the CEL and limp mode issue addressed.
      07-23-2014, 09:58 AM   #10
gmd2003
gmd2003's Avatar
352
What were the specific error codes?
      07-23-2014, 10:04 AM   #11
wrsbmw
wrsbmw's Avatar
108
Don't know yet, just dropped the car at 7am.
      07-23-2014, 10:11 AM   #12
gmd2003
gmd2003's Avatar
352
Sorry I assumed you had a OBD scanner since you went with an aggressive list of mods . I would strongly suggest getting one .
      07-23-2014, 10:28 AM   #13
wrsbmw
wrsbmw's Avatar
108
Yeah, might be a good idea.
      07-23-2014, 10:31 AM   #14
greentrbo95gst
greentrbo95gst's Avatar
1231
Drives: 21 M5 Comp
Keep us updated. Curious to see what happened.
What mods did you go with?
      07-23-2014, 11:26 AM   #15
wrsbmw
wrsbmw's Avatar
108
Noelle Downpipes on order and Dinan Stage 2 with Cold Air Intake and Dinan Exhaust. The only thing not on is the downpipes.
      07-23-2014, 03:10 PM   #16
Timberwolf
Timberwolf's Avatar
196
Drives: People crazy
What was your fuel level? I got a DT malf when I had less that a quarter tank then went up the ramp to my shop.
991 Turbo
993 GT2 Outlaw
      07-23-2014, 03:38 PM   #17
wrsbmw
wrsbmw's Avatar
108
No, it's airflow issues. Has to do with the airbox having a hole in the bottom. There are three different versions, hole, snorkel and closed. DTronics only works with the closed version and they have seen this before so I think they are sending the bottom plates without holes to the dealership.
      07-23-2014, 09:02 PM   #18
Timberwolf
Timberwolf's Avatar
196
Terry Burger said that the snorkel at the bottom helps prevent the cel. Even with the hole.
      07-23-2014, 09:16 PM   #19
Spinny02
Spinny02's Avatar
Dinan setup is a bit different. They are having air enter the box from before the radiator ( lots of forced positive psi) so I. This case they must be getting some kind of odd flow in from the new intake and trying to exit the snorkel .
      07-23-2014, 10:14 PM   #20
HelzRage
Drives: Reliable
Spinny is correct just by reading the M5 intake product page on Dinan's website.
The first thing to note is that Dinan's cold air intakes have always been closed systems (aka taking air from outside the engine compartment). Having a hole / snorkel grabbing air from within the engine compartment flies directly in that principles face and essentially makes it a hot air intake. So having some sort of plug for a factory hole / snorkel in the airbox seems logical for them. Having the hole option in particularfrom BMW just seems very odd to begin with. Almost feels like a stop gap measure / fix in design but alas I am not an engineer so that may not be the case. Regardless the product page states that the the cold air intake utilizes the stock intake paths as well as adding supplemental / additional ones seemingly from the same area judging by the pictures. If there was a hole/snorkel on the bottom of the airbox bringing in air from a different direction / angle as those original and supplemental pathways the air would mix into a turbulent mess in the airbox and would not flow correctly through to the engine and lead to poor results since its obviously not an optimized airflow.
