08-09-2016, 02:00 PM | #1 |
Rep 24
Tune With Cpo
Hey Guys, I Just Bought A 2013 Mcb M5 That Is Cpo. If I Put A Tune Or Anything On It That Will Boost The Performance Will It Void The Cpo? Thanks
08-09-2016, 02:18 PM | #2 |
GLG-20
185
Rep 369
08-09-2016, 02:24 PM | #3 | |
Hide! My wife's coming!
812
Rep 2,816
Example: If you have a bad turbo, if they see a tune they will void the claim typically automatically. However, per law, they are required to identify what caused the issue but knowing these dealers they are quick to point fingers. If you have a bad exhaust system, its unrelated to the tune, they will accept the claim. I personally am full bolt on, tuned, and modified. I haven't had any issues with the dealers. I have made a good relationship with the SA and techs so they take care of my issues.
08-09-2016, 02:28 PM | #4 | |
Rep 24
THANKS I'M NOT SURE WITCH WAY I SHOULD GO WITH IT. A FLASH OR DO A JB4 |
08-09-2016, 07:30 PM | #5 |
Rep 1,805
Drives: 2014 BMW M5 F10 CP
Get a tune.
x5mad351.50 |
08-09-2016, 08:35 PM | #6 | ||
812
Rep 2,816
08-09-2016, 10:52 PM | #7 | |
Rep 1,805
Make sure you know what you want and ask lots of questions. Make sure you get a setup that's known to work. The guys that get their cars broken have shared their pain on this forum for all of us to learn from. .. It's blast too.
08-10-2016, 12:09 AM | #8 |
Rep 788
I do not believe you can prove this statement "the piggy adds much more wear and tear on the car as its not running as efficient as a tune."
When you use a JB4 logs are taken and everything IS within order if you follow Terry's advice like not using Map 2 on a non-CP car without logging and testing. Without a JB4 eg just a bench tune - you can be running at risk and no way to know other than the tuners say - so- you have to have a dyno session to show AFR's etc are in order. Best set up is JB4, BCM AND a flash. You can continue to get the mst from your car and monitor everything over time. |
08-10-2016, 12:49 AM | #9 | |
812
Rep 2,816
08-10-2016, 01:49 AM | #10 | |
Rep 1,805
I also disagree that the best setup is a stack. Your point is valid that on a tune you have zero idea if something is going to break - but I feel that's down to the quality of the tuner you choose to engage with. I personally believe that there are only a handful of tuners you can go to because I believe they have data logged and made sure their tunes are solid. In my case, I believe the quality of the guy I have chosen to work with. If you are looking at a high whp monster a stack is the way to go unquestionably but for a 700 whp set up, it's far less expensive just to load a tune.
08-10-2016, 02:56 AM | #11 |
Rep 788
I don't believe you can corrolate spark plug and coils on a JB4 - thats anecdotal. I am sure there are many who have suffered plug and coil failures on the OEM set-up and flashs.
What Terry/BMS has said about best set up is not to do with 'wear and tear' etc. There are known protencial problems with all options including flashs so blanket statements on personal decisions and any corrolation on wear and tear need to be taken with a pinch of salt. |
08-10-2016, 08:52 AM | #12 | |
812
Rep 2,816
OP - I'm not saying a piggy back is bad. I'm just saying that in my opinion, a flash tune would be better than a piggy. Having the JB4/BCM/Backend is great as well. I do not recommend the JB4+BCM without the backend. Each has its benefits. I'll just say I've have had the jB4 / BCM and I got rid of it twice and stayed with a tune only.
