08-10-2016, 02:22 PM | #1 |
Rep 822
Looking to get a Tune! Need advice.
Looking to have mine flash tuned. I'm in the Los Angeles area.
I'm running AMS catless right now and I'm considering also adding a jb4. So who do you guys know thats local or in the area that does it. SoCal Also has anyone been able to flash it thru the obd port yet? Also heard about making sure the tamper evident stuff isn't damaged, what's that? Looking for advice and help on this. Like pros vs cons Not looking for a crazy tune that's gonna end up destroying the motor lol
Previous - '11 E90 M3 6MT Stripper Full Cloth
Current- GT3RS,MR e90 and SG E92 Comp |
08-10-2016, 08:21 PM | #5 |
Rep 881
If you're not looking for a crazy tune, then you don't need a JB4, probably just a stage 1 tune. In LA there is Mike Benvo of BPM; he's had a lot of good reviews. I went with Mission and recommend them. I know Mission can flash via OBD, but only after the initial bench flash which requires the ECUs be opened either by drilling a small access hole or by cutting through the adhesive. ESS can be flashed by EAS in Anaheim. GSR is now Trinity Auto I believe.
Whoever you choose, I recommend someone local in case you run into issues. Edit: if you are catless then you can do stage 2 and be in 650+ whp/wtq. |
08-10-2016, 09:11 PM | #6 | |
Rep 822
Anybody figure out to complete the tune with drilling or cutting the ecu? Direct from the obd
08-10-2016, 09:17 PM | #7 |
Rep 1,805
Drives: 2014 BMW M5 F10 CP
I would also speak to dme tuning and m6beast. MSR Stage III is a blast.
08-10-2016, 09:46 PM | #8 |
Rep 822
Where's dme tuning and m6beast location ? SoCal ?
08-10-2016, 11:05 PM | #12 | |
Hide! My wife's coming!
808
Rep 2,816
Everytime I see someone post OBDII flash and I get excited then find out its after the bench flash
08-10-2016, 11:07 PM | #13 | |
Rep 822
What are the factors that are actually being adjusted by the jb4 beside more boost and adding more fuel? Does it eliminate cold start? Also last I checked Can't take of the delimiter with jb4.
08-10-2016, 11:19 PM | #14 | |
808
Rep 2,816
OBDII flashing is only possible ONLY after its been bench flashed. May happen one day but hasn't happened yet. Regarding the tamper proof - most will drill about a 10MM or less hole to give them enough access to do what's needed. Then that hole is covered with an OEM looking sticker. I haven't looked at my DMEs in a while but it is glued together from factory and some decide break it open and that tends to torque/bend/twist the housing sometimes and it never looks the same especially where they reapplied the adhesive to shut it closed. If you have downpipes, definitely ask to get the most out of the tune. If you ask for stage 1 they will give you stage 1. Should be able to get easy 650w with a proper tune. JB4/BCM - This is a good option if you plan to stack and want to exceed that 700whp benchmark, someare able to hit that number with a tune only and supporting mods. The BCM allows you to exceed the boost limits needed to exceed that power range. Of course with that kind of power, you'll need clutches, axels, and supporting mods. Personally, I have no plans to exceed my current limits so I opted not to do a stack and stayed with a tune only. As for JB4 logging and code reading, its a very nice feature but I can do that with a $20 OBD BT dongle and iOS app. They have a decent logging feature with graph and easy to use. Maybe not as pretty as the JB4 but it gives me the info I need.
08-10-2016, 11:30 PM | #15 | |
808
Rep 2,816
Cold Start: Does NOT eliminate cold start, however, if you have valves, it can allow you to close the valves to reduce the sound. Delimiter: Does NOT remove Codes: All it will do is clear the CEL which is not limited to just the Catless downpipes. In other words, just removes annoyance really of seeing that light in your dash. For emissions, if you have that, your car will fail as it will never be in a ready state for the monitors as you just cleared your codes as it appeared.
08-11-2016, 05:02 AM | #16 |
Curve Thrasher
620
Rep 3,773
HCP is another tuner. Halim Cazimi Performance
He provided me w custom tunning. I told him what I wanted and it's running better than ever. I'm currently using the stage ll. After its flashed he was able to remotely go through the obll port and place the files on my car. So he is one of a couple guys in this forum who can do that. I put up a thread from my Dyno run in the engine section so check it out. Can't and won't go wrong w HC Performance. Especially after watching him navigate through the computer. He knows what he's doing. Highly recommended. 694++ hp and going up Last edited by boots; 08-11-2016 at 05:35 AM.. |
08-12-2016, 10:23 AM | #17 |
Rep 822
Going with Mike at BPM
It was nice to actually talked to the person who who's going to actually work on your car. Plus major points that he had an m5. Getting it done in a couple of weeks. I'll Keep you guys posted. Thanks everyone for the input. Grazi
BPMSport3380.50 |
08-12-2016, 10:28 AM | #18 | ||
Rep 822
08-12-2016, 05:24 PM | #21 | |
Rep 1,250
Drives: 20' X3M CP
BPM if your WEST MSR if your EAST IMO.
2020 X3M CP - IND Reflector set | Ceramic Tint
Retired:2015 M5 CP MSR Intake|Carbon Fiber Fender Vents|Meisterschaft GTC catback with LXR mid pipes and ER Catless DPs | BPMSPORT Stage II Tune | RKP Rear Diffuser and Challenge Center piece |RKP Front Lip| Painted Reflectors | H&R Springs | Strasse SM5R Carbon Fiber Wheels | Nitto R888 | |
BPMSport3380.50 |
08-12-2016, 05:28 PM | #22 |
3381
Rep 7,539
Thanks everyone! We strive to provide the best products and service/support is equally important after sale.
If anyone has any questions, please feel free to let me know. Glad everyone is enjoying the tunes!
