02-18-2019, 07:33 PM | #1 |
Rep 541
Cant deactivate MDM
if i am understanding correctly i should be able to deactivate MDM and the light will go off and i will have absolutely no traction control, correct? but I have done everything I have read about driving 7 miles putting everything in mode 3 sport plus but what could i be missing? All help appreciated
02-18-2019, 07:38 PM | #2 | |
Rep 1,890
Drives: M5 CS / iX 50i
If you are in MDM mode and want traction control ON, just press the DSC button once without holding it, and it this should turn off the MDM light and the DSC light You can also go into your i-Drive to configure individual configuration of the M1 or M2 buttons to you liking
https://www.instagram.com/day_laborer/ (DM me from this account) Email: nextlevelautobrokersdc@gmail.com Part-time with Next Level Auto Brokers, LLC https://www.instagram.com/nextlevelautobrokers/ |
02-18-2019, 11:48 PM | #3 |
Rep 541
that is exactly what i want to do. i want the no traction light on and the mdm light off meaning i have no traction control right? all i can do is get mdm and car with skid marks light on at same time or both off at same time. i dont think ive held the trac button for 8 seconds ill try that first
02-19-2019, 12:18 AM | #4 |
Rep 4,209
Yeah just hold down the button for 5-8 seconds
02-19-2019, 01:56 AM | #5 |
Rep 541
02-19-2019, 03:25 PM | #6 |
Rep 541
yeah no that doesn't work. I can either press the traction button that is on the surround of the gearshift knob and it will turn on the MDM light and the car with the skidmarks symbol and if I press it again it will cut them both off there is no way for me to turn MDM off and keep track control off. I'm so confused. but when MDM light is on it lets me spin plenty
02-19-2019, 03:54 PM | #7 |
Rep 123
If you hold down the button by the shifter knob for like 5 seconds they both will be off. On the dash it will show you traction off and mdm light will disappear (meaning it's off)
02-20-2019, 04:50 AM | #8 | |
Rep 541
no matter if im in neutral or in gear or s1 or s3 drive 10 miles , hold the button for 5,10,15 seconds i cant get just the 'car with skid marks' light to stay on and 'mdm' to disappear.. -maybe i need a software update? idk -i also cant activate launch control im assuming because of this which is part of the process (ill never use it) but i want to play with and know everything about this bad ass car |
02-20-2019, 04:56 AM | #9 | |
Rep 541
02-20-2019, 07:20 AM | #10 | |
Rep 606
Did you try programming it into an M1/M2 memory and then activating M1/M2 to see if it works that way? |
02-20-2019, 01:28 PM | #13 |
Rep 222
Your car is some wrong whit acc coding. Try to put this mdm seting on and push acc on. Car should take off acc automatic. If that works fine someone is coding your car that you can’t take all traction control off and this code have to change.
02-20-2019, 07:55 PM | #14 | |
Rep 541
02-20-2019, 09:01 PM | #15 |
Rep 4,209
Made this little video
BeachM5nster273.50 |
02-21-2019, 03:13 PM | #16 |
Rep 541
i'm so glad you made that video because now I know for certain that something isn't working or could this be supposedly previous owner coded it to have European MDM? Because I mean it's like no traction control for me seemingly but yeah I need to go to the dealer
Ickdeep5720.50 |
02-21-2019, 03:51 PM | #17 | |
Rep 123
Find someone with Carly and see if there's an option for it that was turned off or something by the old owner |
02-21-2019, 04:23 PM | #18 |
Rep 385
The manual is confusing on this issue but it seems to be saying that if the "car with slippery road no off" icon is lit all the time, either with the MDM or "car with slippery road with off" icons, there is a system fault.
I think you said you have car w/slippery no off icon, which means fault. The other icon maybe tells which system DSC or MDM is bad. |
