08-26-2017, 08:33 AM | #1 |
Rep 737
H&R Springs vs Comp Springs
What is the difference between drop? I have to assume the H&R is lower right?
My H&R come today. Can't wait to install Last edited by Lowflight; 08-31-2017 at 12:45 PM.. |
08-26-2017, 08:53 AM | #2 |
Rep 579
I believe so, a good measure (approximate) is to measure the wheel centre to arch lip vertically up. Stock CP suspension is 380mm F, 367mm R
Get the car as level as you can and average left and right, you'll be close enough to see how much lower H&R springs are |
Lowflight335.50 |
08-26-2017, 02:40 PM | #3 | |
Rep 5,235
H&R slightly lower than Comp.
Lowflight335.50 |
08-26-2017, 05:41 PM | #4 |
Licensed Drug Dealer
742
Rep 2,271
08-27-2017, 07:26 AM | #5 |
Rep 737
08-27-2017, 07:52 AM | #6 |
Curve Thrasher
623
Rep 3,773
When I had hr the same happen to me as my inner wore out quickly leaving me really pissed off with tons of tire left to run on. And this was after I did everything I could do to get the front end right. Although I liked the way my car handle at that time, I don't like wasting money on tires. After buying kev3, corner balance and alignment I don't have the problem anymore
Country run |
08-27-2017, 04:53 PM | #9 |
742
Rep 2,271
Negative. That probably would have fixed it somewhat.
Did you have to get aftermarket camber arms to get the camber back into spec? |
08-31-2017, 05:35 PM | #11 |
Rep 5,235
Car looks so much better on the H&R's.
Lowflight335.50 carrera2RSL183.00 |
09-01-2017, 09:21 AM | #12 |
742
Rep 2,271
09-01-2017, 01:55 PM | #13 |
Rep 737
09-01-2017, 03:38 PM | #15 |
Rep 5,235
They'll settle well below Comp Spring heights; I was on H&R's before going with KW HAS.
10-04-2021, 12:33 PM | #18 |
Rep 544
I had a blowout. Car is lowered with H & R's. Looks like the negative camber wore out the inside edge of the tire till it blew.
Can this be fixed with a good front end alignment or is negative camber a fact of life with the H & R's and my tires will continue to wear badly? I like the lowered look but not sure its very practical if I'm going to go thru tires.
Nardo Grey/Aragon M5C
Burger Tuning JB4, H & R 550 springs, spacers 13mm front and 10mm rear, Michelin PS4S 285/30/20 front, 295/30/20 rear, Remus racing exhaust, Eventuri V2 intake, Suntek Ultra PPF entire car, ceramic coated wheels/brakes, 20% ceramic tints, assorted CF bits. |
10-05-2021, 03:48 PM | #19 |
Rep 319
You cant adjust the front camber without buying different arms. BMW has different set camber arms and there might be an aftermarket adjustable one.
-=SpeedProtocol=- 2014 M5 Sakhir Orange- BPM Stage 1 - Soul Performance Exhaust - PG Intakes - CarboTech 1521 Pads - Turner Monoballs 2021 M5 Motegi Red- Stock Last edited by SpeedProtocol; 10-05-2021 at 04:27 PM.. |
