09-16-2012, 04:46 PM | #1 |
Rep 287
Is anybody else blowing fuses?
Second time this has happened to me and the car has less than 300 miles. The fuse is the circuit for the driver's seat and the driver's airbag. I'm driving along and it suddenly happens. No discernible reason or cause. Suddenly the airbag warning light pops on with a message to immediately get service and the drivers's seat controls are frozen.
The last time I had my Escort radar detector plugged into the accessory outlet between the cup holders, but the detector was plugged in over an hour before the fuse blew. And of course, the detector is designed to operate out of a cigarette lighter outlet like the accessory outlet in the console. Weird. Anybody else experience this problem? |
09-18-2012, 07:21 PM | #2 |
Rep 287
I'm responding to my own post because this could be important. This is what was reported to me by my SA. After re-wiring my seat, the service manager took my car for an extended test drive (which I had given permission for earlier in the day). After about twenty minutes, he felt the seat's lumbar support start to suddenly inflate even though he wasn't touching the button.
The fuse then must have blown because the lumbar support stopped inflating and the airbag warning light came on. Apparently, if the fuse hadn't blown, the lumbar support might have continued inflating and eventually exploded. At the moment, they are looking into getting a new servo module from Germany. Hopefully they will not have to replace the entire seat. I've now been without use of my car for four days in the two weeks I've owned it--once for a bad seat fan, once for a blown fuse and now two days for the second time the fuse was blown. I really miss my car. |
09-18-2012, 07:39 PM | #3 |
Rep 1,341
Drives: 2013 M5 SSII
If they replace the seat, have them put one in with side bolsters
09-18-2012, 07:40 PM | #4 |
Rep 4,721
sorry to hear your issue. This is the first time I have seen blown fuse issue mentioned in the M5 and the regular 5 series blogs.
Let's hope your dealer can get it corrected ASAP. |
09-19-2012, 02:03 PM | #6 |
Rep 7
blown fuses
I have had two blown fuses in my cigarette lighter. I don't smoke but i have my cell phone charger constantly plugged in. Just had it replaced for the second time. Hopefully it doesn't happen again. I have also had to have my whole i drive system replaced. It wouldn't hold any pre-sets. my car came with amnesia/alzheimers.
03-28-2013, 10:57 AM | #7 | |
dentite
339
Rep 758
Drives: 718 GT4, M2C, JLU392, e92 M3
My cigarette lighter also stopped working. Going to take it in for a fuse replacement. |
03-29-2013, 12:46 AM | #8 | |
Rep 1,341
03-29-2013, 07:14 AM | #9 |
Rep 2,245
this is annoying - subscribed
2016 991.1 911 Carrera GTS
06-28-2013, 03:01 PM | #10 | |
dentite
339
Rep 758
Haysam EDIT: I found the blown fuse, #54 in the glove box. 20AMP fuse, I replaced it and my radar fired right up. Now the wait for the new Escort Max Performance detector. Last edited by ufgtrs2007; 06-28-2013 at 05:04 PM.. |
04-18-2015, 06:46 PM | #12 |
10
Rep 246
i just bblew my fuse too in the cigarette lighter adapter.
i had a cellphone charger and V1 valentine plugged in... the front and the rear console adappters arenèt working. glove box is fine |
04-19-2015, 02:47 PM | #15 |
Rep 395
There was a penny or a dime that fell into the 12volt outlet in the armrest compartment. Check if you have any change in it. That's what was causing mine to blow lol.
04-19-2015, 05:20 PM | #17 |
Rocky
412
Rep 3,085
04-19-2015, 05:26 PM | #20 |
Rocky
412
Rep 3,085
04-20-2015, 06:38 AM | #22 |
Rocky
412
Rep 3,085
