11-14-2016, 02:41 PM | #1 |
Dejan
1751
Rep 4,197
Drives: 2018 Audi S3
Garage List 2013 BMW 335i [10.00]
2015 BMW 228i M Spo ... [0.00] 2013 Ford Focus (DD) [0.00] 2001 Alfa Romeo 156 [0.00] |
When to Upgrade Clutches?
I've ran across some info but it's a bit different going back and forth between the M5 and M3. But as far as I understand it after tuning the M5 and raising the power to over 650-700whtq the clutch needs to be upgraded?
Basically is that the power level one should be making plans for an upgrade? I'm considering an M5, and would prob just do a flash tune and sport cat down pipes.
FBO-PS1 and stuff
11-14-2016, 03:03 PM | #2 |
Rep 843
If i remember correctly stock clutch pack starts to slip around 650. If you are just doing a tune and DP's stock clutches should be fine for awhile. Once you add meth and catless dp's it will easily go beyond what the stock clutches can handle.
Jadar1750.50 |
11-14-2016, 04:09 PM | #3 |
Rep 881
Mine started to slip at 680wtq on the dyno. Its set now at 650wtq and no slipping so far.
2014 "AW/SO"me M5
11-14-2016, 04:42 PM | #4 | |
Dejan
1751
Rep 4,197
Thanks guys. That's pretty much in line with what I'm reading everywhere.
FBO-PS1 and stuff
11-14-2016, 10:43 PM | #6 |
Dejan
1751
Rep 4,197
What are your mods?
FBO-PS1 and stuff
11-15-2016, 05:00 AM | #7 | |
Hide! My wife's coming!
808
Rep 2,816
Others like myself, did not have clutch slippage until about a year after having tunes where as my buddy stated seeing it the next week after he tuned his car. Personally, if I could do it all over again, I'd probably go stage 1-2 and call it a day and be happy. I hear that going the clutch route is a head ache and you loose stock drivability.
11-15-2016, 09:05 AM | #8 | ||
Dejan
1751
Rep 4,197
By stage 1 or 2 you mean just like a flash tune alone or flash and some type of hi flo downpipes?
FBO-PS1 and stuff
11-16-2016, 01:49 PM | #13 |
Dejan
1751
Rep 4,197
Imo it's still defeating the purpose...meth is far more reliable and gives better advantages I.e. Fueling and cooling bs using 2 gallons on top as well.
I could be wrong but I doubt you'd gain anything from 2-3 gallons of e85 while spraying meth the entire time. Not a fan of e85. To unreliable of a mix at pumps and dialing it in is a PITA.
FBO-PS1 and stuff
11-16-2016, 03:36 PM | #14 |
Rep 160
12-13-2016, 12:34 PM | #16 |
Rep 881
Alex@MissionPerformance has said that the manual clutch is much stronger than the DCT; he has tuned the OEM manual M5 to over 700wtq w/o slipping.
2014 "AW/SO"me M5
