      09-10-2012, 07:31 PM   #1
IND-Distribution
BMW obsessed
IND-Distribution's Avatar
9572
Drives: G82 M4 / G87 M2
IND Painted Reflector Installation Procedure
Painted reflectors are among the first additions made by any owner of a modern BMW. The unsightly orange reflectors installed in cars bound for North America instantly break the smooth lines of BMW bumpers, and the F10 M5 is no different.
IND provides painted reflectors as a cost effective solution. We use OE BMW reflectors for a factory fit, and the same paint process we would use to repaint an entire car. Each reflector is sanded, prepped for paint, primed, then painted.
Many enthusiasts enjoy installing their own painted reflectors, so we’ve created this installation DIY to help.
Tools needed:
  • 8mm socket and ratchet
  • Alcohol solvent or cleaner
First, turn the steering wheel to full lock, in any direction. This will expose the fender liner.
With the fender liner exposed, begin removing the 8mm screws near the front reflectors.
Slide your hand behind the fender liner, to access the back of the painted reflector. You’ll need to keep your hand on the back of the reflector to control it’s movement as you remove it from the bumper.
Push on the face of the reflector. This will eventually release the adhesive backing on the reflector from the inside of the bumper, and will free the reflector. Be careful not to drop the reflector inside the bumper during this step, as it may come free suddenly! At this point you can remove the OE amber reflector.
Remove any remaining adhesive tape by peeling it from the inside of the bumper.
Soak a rag in an alcohol-based cleaner, and clean the inside surface of the bumper. This will prepare the area for a strong bond with the new adhesive.
Take the new IND painted reflector, and remove the film covering the adhesive tape.
Slide the reflector into the bumper. Be careful not to touch the adhesive tape during this step.
Align the reflector with it’s opening, and press the reflector against the inside of the bumper. Hold the reflector for several seconds to ensure that the adhesive has a strong grip.
That’s it! Now simply turn the wheel to full lock on the opposite side, and repeat the process.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
      11-27-2012, 05:26 PM   #2
Grayblack
Grayblack's Avatar
182
Drives: E92 M3 and G07 X7
Here are my painted reflectors. Perfect color match by IND.
      01-31-2013, 06:11 AM   #3
Protious
Drives: 2013 BMW M5
A much easier way to get the OE reflectors off is to use a credit card on the edge of the reflector inside the fender, that way you're getting directly to the tape instead of pushing on the reflector.
      09-30-2013, 10:09 PM   #4
savela
savela's Avatar
Drives: 2015 X5M
Their way works quite well. Simply place your hand back there and 'peel' the reflector off the inside of the bumper....requires very little pushing. These mods give a lot of bang for the buck!
2015 ///X5M
2014 ///M6 (traded)
2014 ///M5 (traded)
2011 550i (traded)
      10-01-2013, 09:51 PM   #5
MELLOWYELLOW06
MELLOWYELLOW06's Avatar
331
Drives: 2020 M8 & 2022 X& M50i
What size tape do you need once you remove stock
I got a painted set from s friend but it has no adhesive
      10-18-2013, 03:34 PM   #6
eleven11
eleven11's Avatar
Drives: -F85 X5M-
Just completed the installation, and wanted to leave a few comments. It looks great, by the way (thanks iND ).
There are a total of 3 screws to remove:
1) Above the side camera (around the bottom of the reflector)
2) Below the side camera
3) Near the very bottom of the fender
The screws remove quite easily, so I simply used a small 8mm hand tool, rather than a larger ratchet to reduce unnecessary contact. Same with replacing them.
Finally, the OEM reflector was more stubborn than I was expecting during removal (not too bad, though). I wouldn't recommend it to any aspiring hand models. The key, for me, was slow steady pressure.
2017 X5M - Current
2017 F31 Wagon - Current
2014 M5 ZCP - Retired
2011 135i Coupe - Retired
2007 335i Sedan - Retired
      11-25-2013, 12:22 AM   #7
Spinny02
Spinny02's Avatar
Thanks 11. Did have to remove all three screws.
I also had to use the credit card / hotel rewards point card to help remover the pax side. The driver side was able to be pushed out. Both side left all the sticky, so I had to roll my finger down from top to bottom to get rid of all of it. Cleaned it up with a alcohol pad. Took about 20 min total for both sides.
The driver side is very even with the bumper and looks great. The pax side pokes out a bit more but still look good.
      12-15-2014, 01:55 PM   #8
tommydieselm3
Team M
tommydieselm3's Avatar
Drives: 2022 G80 ON ORDER
Tools needed:
can I have pricing for front and rear for alpine white..for an m4 thanks please pm me asap
      05-11-2015, 06:09 PM   #9
iamvietness
Drives: 2015 M3
thanks for the DYI. super easy.
      07-01-2015, 08:03 PM   #10
Thunder43
Thunder43's Avatar
10
Drives: 2013 F10 M5
Just did mine. Very satisfied. Thanks Nate!
2013 M5 BSM/SS - BMS Stage 1, Turner Race Exhaust, 12mm spacers, KW HAS, Dinan sway bars, IND cosmetic package, LED kit, V12 coded
      01-14-2016, 02:45 PM   #11
greentrbo95gst
greentrbo95gst's Avatar
1231
Drives: 21 M5 Comp
What about the rear ones?
      02-03-2016, 08:21 AM   #12
jayhawk785
this.
      02-03-2016, 02:56 PM   #13
KMORGSM5
KMORGSM5's Avatar
Drives: 14 CP M5
Good write up, just bought some!
      02-15-2016, 10:06 PM   #14
Rearview
This again!
      05-11-2016, 10:28 AM   #15
Gutenguy
Drives: F10 M5.
Used this DIY last night to install my IND's! Thanks for this!!
      09-02-2016, 09:56 PM   #16
BMW BRAD
BMW BRAD's Avatar
Drives: F10 535d M, F31 328d M
Uh, as mentioned above a couple of times, What about the rears???
      09-06-2016, 01:03 PM   #17
IND-Distribution
BMW obsessed
9572
I've linked the DIY for the rear reflectors below:
http://f80.bimmerpost.com/forums/sho....php?t=1003769
Let us know if you need anything else!
      09-06-2016, 07:03 PM   #18
BMW BRAD
BMW BRAD's Avatar
Thanks!
      10-22-2016, 08:36 PM   #19
Lerxst M4
Lerxst M4's Avatar
Drives: F82 M4
Mike,
Do you have a write up (or pointers) of how to do the F12 M6?
I just bought a set for mine and they are just a bit different with the camera actually needing to be removed to replace the reflectors. I thought it;d be easy like my F10 M5 was but once I popped the old one off the camera was holding it in and I can't get my head around there to see how it's attached.
Need to get these AW ones installed! lol
2018 F82 M4 ZCP
2015 F13 M6 ZCP (gone)
2013 F10 M5 (gone)
2008 E90 M3 (gone)
      10-25-2016, 10:56 AM   #20
IND-Distribution
BMW obsessed
9572
Originally Posted by Lerxst M5 View Post
Mike,
The camera is removed from the interior side of the bumper reflector and pulls out. The best recommendation I can provide is to make sure that the fender liner is able to be pulled back enough to take a look at what is holding the side view camera in. Turning the steering wheel opposite lock of the side you are replacing the reflector on will help with visibility of the side view camera mounting. If it is still not visible, removing the wheel will be the next step. Let me know if that helps!
      11-23-2017, 03:25 PM   #21
Flying Ace
Flying Ace's Avatar
4985
Drives: G05 45e, 997.1 & 991.1 GT3s
Is this the same procedure for the M6?
