08-23-2013, 09:45 PM | #1 |
Rep 4,106
Dyno'd at 552whp on a DynoJet, stock car (EAS European Auto Source Dyno)
I stopped by today to meet the team at EAS and took care of the alignment, base dyno and shimmy after spacer install. Those guys are amazing and definitely know what they are doing. I chatted with Tom for a while and he definitely has a lot of knowledge in BMW's and the car industry all together.
My base dyno with no mods came at 552whp on a DynoJet. I was definitely surprised with that, but didnt complain. On to the dp install and another dyno.
08-23-2013, 09:48 PM | #3 |
Rep 1,840
Thanks for sharing. Looking forward to the next dyno. I have never heard a M5 bark like that, impressive =p
08-24-2013, 10:32 AM | #4 |
Rep 4,106
HAHA totally forgot about the dog there. I was thinking you meant the exhaust, but it's so quiet.
08-24-2013, 10:43 AM | #6 |
Rep 4,106
I put them back in for the dyno. I really wanted to have a stock baseline.
Here is the graph. Notice the temperature.
08-24-2013, 10:50 AM | #7 | |
1989
Rep 9,498
Pick mine up next week and want a strong none Oil eating engine.
08-24-2013, 02:50 PM | #9 | |
Rep 646
They are showing the dyno run in STD correction...if they toggle the WinPEP software to SAE correction, it would probably show 5-10hp less. SAE correction takes into account the ambient weather conditions (barometric pressure, humidity and temperature). STD uses the same weather factors but also corrects for elevation which is a manual input by the dyno operator. |
08-24-2013, 03:15 PM | #11 |
Rep 4,106
Definitely did the hard break in from mile 1. Make sure you don't hold rpms at a constant point. It's about hard acceleration and decceleration in gear. Go through the whole rpm range. At 4k miles still no drop of oil wasted.
08-24-2013, 03:17 PM | #12 |
1989
Rep 9,498
Great will do.
08-24-2013, 08:22 PM | #14 |
Rep 4,106
08-24-2013, 08:41 PM | #15 |
Rep 3,041
Not sure what your point is. Incorrect to Dyno the f10/12/13 with hood open. I should have left this alone and I will. It is not correct though. Results suspect at best this way. PM me if you like.
2016 McLaren 675LT - Chicane Grey 2016 Corvette Z07 - Artic White 2016 BMW F86 X6M - Black Sapphire Metallic |
08-24-2013, 09:17 PM | #16 |
Rep 646
I could see how maybe the hood being open could cause something in the computer to retard timing as a safety measure... But in no way would it help improve performance. Yes it might help reduce under hood temps but so would cooler air rushing in at 100+mph which is what you would see in 4th or 5th gear.
08-24-2013, 09:26 PM | #17 |
Rep 1,583
Crazy numbers for stock
2013 M6 Coupe SG, VSE 003's 21, Akropovic Evo Carbon, KW V3, AMS DP's, Vorsteiner Full Aero, Gruppe M Intake, Bel Stir Plus & V1 with HP Laser Interceptors, P3Cars Gauges, JL 2X12W6Subs, 35%tints.
My Thread: http://www.6post.com/forums/showthread.php?t=794659 |
08-24-2013, 09:45 PM | #18 |
Savoir Faire
74
Rep 1,772
Because of intake air temp?
Sold:Imola Yellow RS4-KW V3|MTM 10mm spacers|Hotchkis rear sway bar|APR Stage 1|Milltek Catless|RNS-E|Euro RS4 Flat bottom Steering Wheel Sold:E46 323i |
08-25-2013, 05:32 AM | #19 |
Rep 5,109
Apparently there is a longish procedure on how to properly dyno these cars to avoid all the different sensors giving false feedback to the DME/ECU. To get consistent and reliable numbers these procedures are claimed to be essential.
Agree that abandoning these "safety" measures won't increase power, but it might not give reliable and comparable readings. Have seen some dyno reports that gets strange behaviour and different results on multiple dyno runs. I don't know ANYTHING about these procedures. Just saying what I have read elsewhere |
08-25-2013, 09:15 AM | #20 | |
Rep 3,041
08-25-2013, 02:23 PM | #21 |
Rep 4,106
Always seen dynoes are done this way. I would think it helps especially when your car is inside of a hot shop. Let me know why it's bad. It's always good to hear other opinions.
08-25-2013, 02:33 PM | #22 | |
Rep 4,106
