      03-27-2017, 03:45 PM   #1
kuruca
Drives: 488 GTB, m4, Levante
Drivetrain malfunction help needed.
I have been getting drivetrain malfunction for lastcouple of days
First it was going away after restarting the car but now it s there, i thought it could be the gas i drove it untill the light come up, filled up again clean the maf sensors and reset it came back again, i used code reader to read the code what it comes up, any one here had same codes 3 codes total , thank you
P10F3 manf cntrl fuel&air metering auxiliary emission controls
P10F3 manf cntrl fuel&air metering auxiliary emission controls (pending)
P12A8 manufacturer control fuel&air metering ( pending)
      03-30-2017, 12:33 PM   #2
VoytekM5
Drives: 2013 M5
Sounds like a bad O2 sensor.
I had the malfunction pop up on my car. It was a bad ignition coil.
      03-30-2017, 07:40 PM   #3
kuruca
I cleared with cheap code reader it came right back on , and i went my friends garage cleared it woth snap on tool it didnt come back on so far
      04-09-2017, 06:20 AM   #4
TrevorM3
Drives: 6.3 AMG
warranty?
      04-09-2017, 07:00 PM   #5
kuruca
Originally Posted by TrevorM3 View Post
warranty?
Warranty already ended, it comes back on and of the codes are still same a
      04-22-2017, 01:41 PM   #6
Loidas
Lithuania
Drives: Bmw F10 M5
I had the problem with drive train and fuel air metering the problem was a very small crack in air intake collector. Hope this helps.
      04-23-2017, 10:00 AM   #7
kuruca
Do you remember where it was any pictures will be appreciated
      04-23-2017, 05:55 PM   #8
Loidas
Lithuania
Drives: Bmw F10 M5
You should go and scan it with normal computer with bmw software, because with every error code it gives a possible solution to solve it. As soon as you will see / post possible solutions more people will be able to help including me because I suppose these errors can occur because of many thibgs invokving fuel and air systems in m5
      04-23-2017, 08:00 PM   #9
kuruca
Where can i get bmw software?
      04-24-2017, 03:09 PM   #10
Loidas
Lithuania
Drives: Bmw F10 M5
You should find an electrician ormgo to bmw dealership for them to scan those error codes normally and tell you the solutions
