11-20-2015, 04:04 PM | #1 |
Rep 1,519
Pure Hybrid Turbo on F10 Manual M5
Customization done by AutoCotoure and help of Middlyman Frozen M5
mods are MSR Fabwork Downpipe Meisterschaft Exhaust UUC Short Shifter ACM Tune Stage 3 Meth Kit Jb+BCM (Tweaked by my Tuner Kevin at Precision Tuning in Spotswood NJ) here is a little preview of what Hybrid Turbos can do still need to do more but this is our first dyno so we expect more from this car soon DynoJet stage 3 w/meth flash only put out 640/610 on the wheels after Hyrbid Turbos 729/745tq Stage 3 ACM tune + JB/BCM From what I notice and I'm sure a few will chime in. but the turbos spool so loud now too and its crazy loud and i feel that it brings the meisterschaft ALIVE.Theres a lot more potential for this car so well see how it hold up on Stock clutch but that should not be a problem Last edited by NightM; 11-20-2015 at 04:16 PM.. |
11-20-2015, 05:48 PM | #2 |
Rep 616
Keep us updated on your performance.
Looks very promising. You'll need a new clutch soon enough. Have been reading of more then a few that needed it with lower gains then what you posted. Nice work |
11-20-2015, 09:23 PM | #3 | |
Rep 1,519
well keep you posted and I'm sure middly will chime in also |
11-22-2015, 09:28 AM | #7 |
1087
Rep 1,968
Likely 800whp is possible - the main advantage is better flow at moderate boost levels. This system is completely turbine limited so any major gain won't be available until we have the S2.
11-22-2015, 05:33 PM | #8 |
Rep 6,067
Nice... But I'm sure 800 whp will break either differential or driveshaft or or axle or DCT ..... or all of them...I doubt this car is designed to be able to tolerate that much twist since you are talking about +1000 NM torque at crank shaft for a DCT with nominal input torque capacity of 700 NM. I admit Germans are conservative and always underrate everything but not over 40% ... IMO
11-22-2015, 08:32 PM | #9 | |
1087
Rep 1,968
11-22-2015, 08:37 PM | #10 | ||
Rep 715
11-22-2015, 09:11 PM | #11 | |||||
Rep 1,519
just tested it till a good speed and its holding it very well we were both shocked that hybrid can do this. made a thread on the "VS" so take a look there. |
11-22-2015, 09:14 PM | #12 | |
Rep 6,067
11-23-2015, 05:23 PM | #13 | |
Rep 1,519
11-23-2015, 07:16 PM | #14 |
Rep 792
11-23-2015, 09:50 PM | #15 | |
Rep 2,202
Thats rated for 1200wtrq and probably safe for 1300-1500wtrrq if you want to take it a little further. PG V 2.1 Nissan GTR R35 6spd H/C Synchro Set Dodson Pro Max clutch/Alloy version ( Sheptrans spec ) Dodson Heavy Duty clutch return spring seals x 2 Dodson Heavy Duty clutch return spring retaining clips Dodson Piston shaft seals Dodson FWD retainer Dodson Mechanical lock #1 Dodson Mechanical lock #2 Dodson Selector Piston Shims x 4 Dodson O-ring and seal upgrade kit Dodson Oil pump shaft upgrade with blueprint Dodson Reusable transmission filter 6 neodymium magnets Dodson High temp rear differential oil seal ShepTrans FWD ball retainer ShepTrans Billet front thrust plate Dodson FWD clutch Fluid Dodson Fwd output seal DodsonOutput shaft end float shim Dodson 2,4,6 Thrust bearing circlip Dodson 1,3,5 Thrust bearing circlip Oem Nissan transmission pan gasket Transmission and Rear differential Fill plug gasket (2) Rear differential drain plug washer x1 Oem Nissan Rear differential side seals T1 rear diff brace Arp Rear diff bolt upgrade Dodson Surge/Baffle kit Sealer/Loctite Motul 75/140 FF If you did clutch, and axles I don't think you'd see much break. Especially with Dynojet numbers. |
11-23-2015, 10:58 PM | #16 | |
Rep 6,067
I was talking about RWD M5 with GETRAG Powershift 7DCI700 DCT rated to 700 NM with very short gear ratio of 4.8 at first gear. You are talking about an AWD car with 4.05 gear ratio... almost 20% longer than MDCT... Do you know the torque transferred to driveshaft is multiple by gear ratio? and do you know AWD will split the torque to 2 different axle? Your GTR is completely AWD when you launch so the 1000 wtrq you are referring to is split between 2 axle and is transferred via 2 different shaft... In addition your GTR is about 600 lb lighter than M5... You need to know some basic physic to realize the big difference here ...It's not apple to apple comparison. 1k wtrq at hard acceleration will break the driveshaft or differential or transmission right away if it's on M5/M6... even GTR if it was RWD, unless you completely change everything (differential, transmission, driveshaft, axles, joints,...).... well then it's not the same car anymore LOL Wondering how soon you would reach 2000 wtrq
11-24-2015, 09:44 AM | #17 | |
Rep 406
You keep comparing two completely different cars here. The gtr is probably one of the best street/race cars for the money that's out there. I had a Switzer USE gtr and there is no way you can compare the two. The M5 is a luxury family car that is fast, but will never be race car. It will never be what a gtr can be. For 10k you can make a gtr into a monster and it will out perform pretty much any m5. That being said, if you're buying a m5 for a drag/race car, you're wasting your money. We all know your gtr is going to be faster and handle better. I do understand the gtr weighs a lot, but it also has awd which helps a lot. The only downfall of a gtr is that you can basically only fit 2 people in comfortably, it's not a family car, and it's doesn't have the luxury that a m5 has. In 2 1/2 years, I'll most likely pick one up as our daughter will be an adult and we won't need a bigger car haha! I miss the gtr a lot but like I said before, you can't compare these two cars at all. |
11-24-2015, 09:45 AM | #18 | ||
Rep 2,202
I'm just saying, send it to shep lmao thats the easiest solution lmao. Depends car starts to become a dud in the 35R sizes, I was going to do top mounts for 1700+ and they advised me not to do it given how it would drive as a street car because it would just not be fun even though it would make power lol Quote:
I mean I wasn't comparing them... I was just saying if you build the trans with the right people it SHOULD be fine. Tough crowd in here and if you had a USE you were faster than me |
11-24-2015, 10:19 AM | #19 |
1087
Rep 1,968
Nobody knows what will break first. If you keep dragging the M5, may break the drivetrain even at moderate boost. If you are roll racing and strive for MPH, you may break the motor.
I do both... something is bound to break! |
11-24-2015, 11:45 AM | #20 | |
Rep 2,202
750wtrq is like 6 something on a mustang which should be fine. |
12-10-2015, 01:12 PM | #22 |
Rep 2,202
