03-17-2017, 10:49 PM | #1 |
Rep 628
Got the car DYNO'd today
I had 3 pulls on my car today, car has RPI catback exhaust, gruppe m intake and BMS stage 1.
does this look right? these are corrected numbers with a correction factor of 1.2212.
2013 M5 Space Gray, Piano Black|Night Vision|Every option|6MT|RW Carbon front Lip|Vorsteiner Rear Diffuser|
2019 x7 50i White, Loaded | chrome delete | black grill | Previous: 2015 X5 Graphite, |All options| - 2014 435i Xdrive Msport, |Fully Loaded|6MT|FBO|JB4|Front,side,rear lips/spoilers|- 2015 320i Xdrive, |Wife's beater| - 2008 535i Xdrive |
03-17-2017, 11:14 PM | #2 |
Rep 715
Your pic isn't very clear but from the numbers I can see it looks about right.
03-17-2017, 11:20 PM | #3 | |
Rep 628
peak torque is 603.9 on first pull, then 536.6, and last pull 569 peak power corrected first pull 548.8hp then 513.2 and last pull was 527.2.
03-18-2017, 10:34 AM | #4 |
Rep 7,886
That's about right. When I ran that setup I was making somewhere in the range of 600-650 crank horsepower. The BMS Stage 1 is giving you the most gains, while the RPI might net you a few hp, but the Gruppe M Intake might be causing hp loss or no gains, those things are really just for looks. The stock intake with the charcoal filters removed give you the same as Gruppe M.
Mkai030.00 |
03-18-2017, 11:01 AM | #5 | |
Rep 628
I'm going to swap back to stock then. love the sound of the intake though...
03-18-2017, 11:24 AM | #6 |
Rep 881
I thought those numbers were closer to a stock setup, OP, but then I see you are in Denver, CO. Did you dyno before those mods?
2014 "AW/SO"me M5
03-18-2017, 11:46 AM | #7 |
badgtr
62
Rep 132
What kind of dyno is that on? Numbers look real low in my opinion. I have seen 550rwp stock on a dyno jet. Are you sure those are corrected numbers? If those are actual at that elevation that would be damn good. But corrected with a 1.22% correction factor means your only making about 425-430hp.
03-18-2017, 07:55 PM | #8 | |
Rep 628
03-19-2017, 07:38 PM | #9 | ||
Rep 822
I put down 701hp and 710tq.. You will love it
Previous - '11 E90 M3 6MT Stripper Full Cloth
Current- GT3RS,MR e90 and SG E92 Comp |
03-20-2017, 01:37 PM | #10 |
Rep 628
Which tune are you running?
I'm currently running the BMS Stage 1, the dyno pulls had the stage 1 on it.
03-20-2017, 03:05 PM | #11 | |
Rep 822
03-20-2017, 03:06 PM | #12 |
Rep 628
What other mods do you have other than the tune?
03-20-2017, 03:11 PM | #13 | |
Rep 822
Stock intakes at the time of dyno with charcoal delete
03-20-2017, 03:50 PM | #14 |
Rep 501
Is this with 91 or 93? Any other goodies?
03-22-2017, 06:15 PM | #15 | |
Rep 822
03-23-2017, 11:09 PM | #16 | |
Rep 1,519
Better to do Uncorrected as u will know Exact numbers it put down at that time,weather,elevation all that crap. Ask for Uncorrected numbers then you will know what it put down that day exactly. Btw I had Old Jb also back then it put down 650whp 670wtrq Mods were Full Custom Exhaust/dp Bmc filters Jb Pump 93 |
03-24-2017, 03:57 AM | #17 | |
Rep 232
What tune do you have now?
03-24-2017, 09:14 AM | #18 | ||
Rep 1,519
That user name is familiar |
Mkai030.00 |
