11-17-2016, 05:35 AM | #1 |
Rep 182
another drivetrain malfuntion.. no boost
Hey guys need some help I will attach pic of some of the codes that are associated with the drivetrain malfuntion....
I can re-start the car and it won't go away.. and I got no boost.... I doesn't accelerate more than 3.5 rpms... any clues? |
11-17-2016, 05:48 AM | #2 |
Rep 594
i use icom os for bmw , but your description fault mean error coding ,
you made any flash or prog ? and did you check wiring for dme , please recode your dme after check your wiring and plug connection Last edited by wheelpro; 11-17-2016 at 09:05 AM.. |
11-18-2016, 10:30 PM | #5 |
Rep 402
whats done to the car??
Redrckt135429.50 |
11-19-2016, 12:04 PM | #6 |
Rep 182
well I guess they found some water inside the JB 4 box... so I will replace the board!!! thx u guy for the input... hopefully is just the JB4...
my car has JB4 IPE EXHAUST MSR intakes ssp spec-x clutch pure turbo stage 2 ESS FULL TUNE... drive shaft and rear axle by DSS |
11-20-2016, 07:17 AM | #8 |
Rep 182
very good... I am having problems with the trans. torque limiter.. if I drop gear in automatic on full throttle.. the trans closes the throttle to like 40% and progressively open up... this info was logged by my tuner... so I don't know what to do to improve this problems
11-20-2016, 07:39 AM | #9 | |
Rep 1,300
11-20-2016, 08:50 AM | #10 |
1087
Rep 1,968
What do you mean drop a gear at WOT.... downshift?
How do you know it's the trans doing this - what are your torque limits? Is boost going over target |
11-20-2016, 01:35 PM | #11 | |
Rep 1,300
Car essentially overshoots from 4th to 6th gear and 5th goes missing lol And if you have a severe case like ..me. You will get this along with drivetrain and codes lolZ we shall see what issue is this soon though |
11-20-2016, 09:44 PM | #12 |
1087
Rep 1,968
Yes I know the issue very well - had it and changed my trans as a result. Didn't realize he was referring to that.
The rod 5-7 happens when redlining 4th and going into 5th in S3 mostly although mine got to a point it did it every time even with stock flash. SSP has the old trans and is helping figure it out. |
11-20-2016, 09:58 PM | #13 | |
Rep 1,300
11-20-2016, 11:35 PM | #15 |
Rep 1,300
11-21-2016, 08:28 PM | #16 | |
Rep 966
These are failing on stock and modified cars. 2 intercooler sensors and 2 sensors in the intake manifold. They give the same fault description that you are getting : Charging Pressure |
