10-11-2021, 10:27 AM | #1 |
Rep 29
Installed Dinan sway bars, now have suspension noise
Hi all,
I had Dinan sway bars installed on my F10 M5 a couple of days ago. As soon as I got the car back I noticed that every little clunk and creak from under the car that I used to have now seems to be amplified 10x. It's like there is a mic under the vehicle sending the noises right into the cabin. The vehicle drives fine, but the suspension is very noisy on all but the smoothest of surfaces. I consulted with a friend who is a knowledgeable car guy and he reckons that the stiffer bushings in the Dinan sway bars are responsible for the noises, and they just need to be greased some more. I'm not entirely convinced with that explanation because even pre-existing suspension noises that came from other parts of the underbody (not related to the new bushings) are now louder. Anybody here have a similar experience with these sway bars, or have any ideas on what's causing this? |
10-11-2021, 04:58 PM | #2 |
Fueled by Recycled Dinosaurs!
630
Rep 1,171
Drives: F06 M6
I haven't had any experience with their sway bars but if they use the harder polyurethane bushing you'll likely hear more noise. My experience with poly bushings on a C3 vette restore I did drove me bananas.
Supposedly if you dope em up with enough grease it can provide some relief from the noise.
10-14-2021, 01:19 AM | #3 |
Rep 538
I've had no such issues with mine. If you press down on the car so that it noticeably moves up and down on the suspension, do you hear any creaking noise?
Poly bushings definitely like to be well greased. |
12-14-2021, 08:12 PM | #4 | |
Rep 396
current: 23 g20 m340ix
12-24-2021, 07:24 AM | #5 |
Rep 19,548
If still a mystery your best bet is to put it on a rolling road brake tester (but not to test the brakes) to pinpoint more where the noise could be coming from.
Tags |
dinan, sway bar |
