      11-09-2017, 08:01 PM   #1
SalM
S1N1ST3R
SalM's Avatar
Montenegro
143
Drives: E92 M3
Diff Braces?
Anybody running diff braces in our cars? Lock down the differential to eliminate some wheel hop could help save our axles big time. Did a quick search didnt find much on this topic.
Anybody running a diff brace ? Where can we get one ?
2012 E92 M3
World's Fastest N/A E9X M3 & Stock Motor Supercharged E9X M3
11.49 @ 121.54
10.38 @ 136.04
      11-10-2017, 01:17 PM   #2
allmotor_2000
1087
Drives: 2018 RS3, 991 Turbo
I am designing one... available shortly
      11-10-2017, 01:29 PM   #3
MpowerMike
MpowerMike's Avatar
361
Drives: 2012 IB BMW M5
Interested
      11-12-2017, 09:03 PM   #4
SalM
S1N1ST3R
SalM's Avatar
Montenegro
143
Drives: E92 M3
Awesome ! How we looking on cost ?
2012 E92 M3
11.49 @ 121.54
10.38 @ 136.04
      11-13-2017, 01:49 PM   #5
allmotor_2000
1087
It's made from a solid billet piece... so expensive. I need to test-fit and then will put up a post for people who may want to purchase.
      11-13-2017, 02:30 PM   #6
Used2be
Perennial PFC
Used2be's Avatar
Drives: F90 M5 DG/Aragon
Do you have the capability to replace the circular section in your brace around the bolt that goes through the rubber bushing in the stock piece? Perhaps with Delrin or something with at least some slight deformability?
In pictures of those braces that have failed, the mounting bolts have also been broken. Your brace appears unbreakable, will that put more load on those bolts, or serve to save them?
In regards to SalM's question, I don't believe wheel hop in an IRS will be solved with this brace. I'm willing to be proved wrong.
      11-13-2017, 02:57 PM   #7
allmotor_2000
1087
Yes option for solid and bushing as well - TBD on material. Also bolts will be class 12.9.
      11-13-2017, 03:20 PM   #8
Used2be
Perennial PFC
Used2be's Avatar
Excellent. For a DD it might be important. Even for serious dragstrip use some give might be helpful. Are there other rubber mounting points that should use more solid bushings to complement your support?
      11-13-2017, 04:52 PM   #9
allmotor_2000
1087
The front diff mounts have rubber bushings so there will be some give. I believe one of the reasons the rear gives is due to excessive flex on that rear bushing. If it were rigid that flex goes away but who knows where it will break next!
      11-13-2017, 06:28 PM   #10
Used2be
Perennial PFC
Used2be's Avatar
You will show us in the next months! Thanks for your willingness to pave the way for the rest of us.
V8munro49.00
      12-02-2017, 09:21 PM   #11
schnell1982
Drives: FAST
How many stock differential mounts have broke ?
      01-02-2018, 09:27 PM   #12
BMWAUDIO
Drives: F90 M5 Frozen Gray , 997 C4S
2 On my car .
first one broke when Allmotor had the car and it was replaced just before i bought the car and that one broke about 6 months later
      01-14-2018, 10:28 PM   #13
allmotor_2000
1087
Like 30-40...
      01-15-2018, 08:57 PM   #14
steeve13m
would designing a metal bushing to replace the rubber one make sense instead of the entire mount?
      01-16-2018, 12:20 PM   #15
allmotor_2000
1087
Yes, that's the plan. The metal version was for fitment
      01-16-2018, 12:48 PM   #16
Used2be
Perennial PFC
Used2be's Avatar
My take on steeve13's question was that he wants to retain the stock cast brace and replace the rubber in it with a metal bushing to surround the mounting bolt. I hope he'll chime in with his intent, but if that was it I don't think the stock casting would hold up.
      01-16-2018, 12:53 PM   #17
allmotor_2000
1087
Stock casting is weak.. it cracks very easily
      01-16-2018, 01:51 PM   #18
Michaelmabill
Drives: Bmw f10 m5
Wher Can i buy this?
      01-18-2018, 03:34 AM   #19
V8munro
V8munro's Avatar
Drives: F10 M5 Sakhir Orange
I have MT's and looking to 1/4 this year again on them. Is there any work around getting the oem diff braced before yours goes into production and what part is usually breaking the rear?
F10 M5 2013 Sakhir
Eventuri Intakes, Supersprint backboxes, catless downpipes, ssp spec r, ECU flash, JB4 BCM and BMS dual CM10 meth
Insta: Tommy_turb0
      01-23-2018, 08:11 AM   #20
JuniorM3
JuniorM3's Avatar
Ethiopia
134
Drives: BMW F13 M6 CP GT3
I NEED ONE ASAP!!!
Nice job!
keep us posted
F13 M6 CP GT3 | Mineral White | 20'' BC Forged Center Locks | Fully Loaded | JB4/Meth | Custom GT3 Widebody Kit + Aero | Catless DP/X-Pipe | Turner StrackSport Discs/Pagid Brake Pads |
