03-09-2019, 11:26 AM | #1 |
Rep 76
Water getting into battery compartment
Has anyone else experience this? I have noticed every time my car gets a wash or it rains water fills into my battery compartment with the other modules! I already had to replace my battery and 2 of the modules due to water $1600 ! I called BMW North America and told me it could be from the sunroof drain plug and that's normal "maintenance".
03-09-2019, 12:56 PM | #2 |
Rep 1,107
I believe you can blow out the drains for the sunroof or take weed wacker trimming line and push it through the drains to clear any blockages. GL water leaks are the worst.
Edit for more info: If you look in the rear quarter panels I believe the roof drains dump out behind the rear wheels. I think the hose may run right past the battery. Try to find this hose I bet it's clogged. You should be able to see it behind the tire. Good luck
OneExtra810.50 |
03-09-2019, 02:20 PM | #3 |
Rep 19,791
How would it get through when sealed shut washing the car; Zanderza a while ago had the same problem of water ingress into the trunk though it was coming through an after market boot spoiler.Water caused a diff control problem with no dsc available which he eventually rectified.
03-09-2019, 04:11 PM | #4 | |
Rep 1,107
03-09-2019, 04:53 PM | #5 |
Rep 19,791
03-09-2019, 05:08 PM | #6 | |
Rep 816
03-12-2019, 03:41 AM | #9 |
Rep 19,791
Left the beast outside and it's been raining all night.After wiping water away from the sun roof area and on opening it there was no sign whatsoever of water ingress not even a trickle in the channels there.
03-12-2019, 03:59 PM | #10 |
Rep 385
In past BMWs clogged sunroof drain usually leads to dampness in the back seat floor, bench or B/C pillar. Battery area flood I haven't seen but I've not dealt with this on F10. Usually water in trunk is from lid or taillight cluster seals going bad
