04-24-2014, 04:57 PM | #1 |
Rep 1,622
Anyone know how many miles you can get once the tank range shows up as "Range ---- Miles" ?
In the E60 M5 I could get another 8-10 miles after the "----". Curious to know if anyone has pushed it 5 or more miles after zip in the F10. I had pushed it 3 miles past earlier today.
04-24-2014, 05:09 PM | #3 |
Rep 1,622
What is the M5 fuel tank capacity, 21 gallons? I don't usually fill the car, but did this time. It took 20.728 gallons.
So after the "----" comes on, you have roughly.. between half a gallon - one gallon in the tank?
04-24-2014, 05:11 PM | #4 | |
Rep 1,837
so u were definitely good to go for another couple of miles u have cheap petrol, full tank m5 here of ron98 is 120+ gbp |
04-24-2014, 05:24 PM | #5 |
Rep 1,548
I actually ran out of gas on the way home from the track!!!!
My distance to empty indicator read "3 miles" FYI!!!!!!
CURRENT:
His: Porsche 991 Turbo S Carrera white/Black Hers: BMW X3MC BSM/Black |
04-24-2014, 05:37 PM | #6 |
Rep 1,837
04-24-2014, 06:30 PM | #7 |
Rep 1,622
The hardware must not be accurate enough to allow the driver to calculate exact amounts of fuel. Therefore BMW must have a correction range.. aka reason why under normal driving conditions you have more fuel after "---".
04-24-2014, 07:55 PM | #10 | |
Veteran U.S. Army
60
Rep 771
04-24-2014, 08:03 PM | #11 |
Rep 422
Dont forget that running low on fuel usually results in a Drive train message
2004 GT3 (Track and weekend toy) 2016 Cayenne (Daily driver) 2011 Turbo PDK (Retired) 2013 M5 Black Sapphire( Retired ) |
04-24-2014, 08:05 PM | #12 | |
Rep 365
2015 ///X5M
2014 ///M6 (traded) 2014 ///M5 (traded) 2011 550i (traded) |
04-24-2014, 08:05 PM | #13 |
Veteran U.S. Army
60
Rep 771
WOW,...... over $200 to fill the tank? Do you guys have real gas there, or is it 10% ethanol, 87% gas and 3% water like we have in the US?
04-24-2014, 08:28 PM | #14 |
Rep 1,622
Yes, by the way important to know:
Sometimes it's unavoidable.. you run the car to near empty. However if you actually run the tank dry, that could mess up the fuel system and if that happens you'll need to bring the car in for repairs.I think usual issue that happens is air in the fuel lines / fuel pump motor fails from being run dry. So - try to avoid very low fuel scenarios at all costs.
04-24-2014, 08:36 PM | #15 | |
Rep 1,622
Ever since getting bad gas (three times) at Mobil in my E60 M5 ownership days.. I always try to fill up at those top tier gas stations. So I always go to Shell and when I can't, I go to Chevron. Never fill up when tankers are present. Luckily I haven't had any gas issues in a long time.
04-24-2014, 10:05 PM | #16 |
Curve Thrasher
623
Rep 3,773
04-25-2014, 05:22 AM | #17 | |
Rep 22
How do you get that on the display? I simply see the range drop to three horizontal lines, that's it. |
04-25-2014, 05:27 AM | #18 |
Rep 1,837
04-25-2014, 05:28 AM | #19 |
Rep 1,837
04-25-2014, 07:15 AM | #20 |
Rep 784
04-25-2014, 07:43 AM | #21 |
Rep 1,700
weird why the US have a different gallon measurement to UK.... all our fuel tanks are 80 litres. which is 17.6 UK gallons. I always fill up on 99ron juice. do you US guys have to put additives and octane boosters in your fuel tank every now and then, or are the ECUs set to allow for lower ron fuel?
