      07-11-2014, 06:37 PM   #1
Bmill4
Drives: M5/X6/X3
Paddle Shift Problem
I'm looking to see if you guy can help me out where my dealer is failing me.
The left paddle is having issues. Many times it will not down shift the transmission, even though I'm clearly within the RMP range for a down shift. Sometime if I click the paddle a second or third time it will work. If It grab the stick it will down shift at that moment just fine all the time.
The dealer already replaced the paddles and that has not helped. The dealer also says they can see a stored fault code.
Going back in again this week and I'm a little concerned they are going to do more head scratching and fixing.
Thoughts?
Thanks!
      07-11-2014, 06:57 PM   #2
CFisher
Drives: F10 M5 Black Sapphire
Solenoid/s on the DCT need replacement? Seems I've heard this before...
Edit: Just a guess here...most w/solenoid issues have a Drivetrain malfunction error showing...
      07-11-2014, 07:01 PM   #3
emmfive
emmfive's Avatar
74
Drives: 2001 M5
Does this happen on any downshift or just 2-1?
      07-11-2014, 08:58 PM   #4
Bmill4
Drives: M5/X6/X3
CFisher, thanks for the thought. I will add that to the list.
Emmfiv3, I'm not sure if it does it in ever gear but it clearly does it in the 2-6 range. Not sure if I have ever seen it happen in 2 to 1, I will give that a try tomorrow and pay better attention.
      07-12-2014, 12:45 PM   #5
emmfive
emmfive's Avatar
74
Drives: 2001 M5
Sometimes I'll have to hit the paddle a couple times to downshift to first, usually at parking lot speeds. The issue doesn't manifest with any other gear change. So it sounds like your issue isn't the same as mine.
      07-12-2014, 11:38 PM   #6
shahano
Solenoids
      07-13-2014, 01:05 AM   #7
avlnch
Drives: 2013 Individual M5
OP's issue sounds unrelated to the paddles in mechanical sense.. probably something relating to the trans/shift process/DCT electrical
@emmfiv3 next time you drive try to downshift extreamly slow with the left paddle. See if the car downshifts before your paddle makes an audible noise (pressed fully).
Then do the same on the right side and see if the up shift paddle shifts only at the audible click and not before.
I experience this with my car, but it doesn't bother me.. almost a beneficial problem to have.
      07-13-2014, 12:58 PM   #8
Jay-K
Jay-K's Avatar
Indonesia
384
Drives: Slow
I think yours have some problem with the paddle or the electrical wiring..
since you downshift just fine with the gear knob.
      07-13-2014, 03:11 PM   #9
cnes
cnes's Avatar
23
Drives: E39 M5, F10 M5, F13 M6, F80 M3
What rpm at u try to downshift? is the car at full temp? I have this happen a couple of times. But it was at low speed and the car was still warming up
