12-09-2014, 09:05 PM | #1 |
Rep 129
Sport Plus mod, shift problem
HI guys,
I need help When I am using the sport plus mod it won't down shift like spot or normal mod, is this normal? Here is the issue, when I am driving about 65mph it's on 6th gear when I step on the gas it won't go to lower gear however the car still pick up the speed slowly. Please help Thank you
13 M5
14 GS350 F Sport 10 Audi Q5 94 MR2 Turbo |
12-09-2014, 09:20 PM | #2 | |
Rep 6,067
And are you talking about Drive mode or Sequential mode? In Sequential mode you have to: Kickdown: for maximum acceleration, e. g. when passing. To do this, depress the accelerator pedal past the resistance point, and pull the left shift paddle once or push the shift lever forward once. In Drive mode you have to: Kickdown: for maximum acceleration, e. g. when passing. To do this, depress the accelerator pedal past the resistance point
12-09-2014, 09:26 PM | #3 | ||
Rep 7,885
12-09-2014, 09:28 PM | #4 | |
Rep 129
I stepped all the way to the floor, but it won't down shift , I am on S3 mode
13 M5
12-09-2014, 09:32 PM | #5 |
Rep 129
Sorry I am wrong , actually it's on drive mod.
13 M5
12-09-2014, 09:54 PM | #7 |
Rep 129
I did floor it, but it won't down shift, that's why I drop my car at the service today but they said its normal,
13 M5
12-09-2014, 11:43 PM | #8 |
Rep 6,067
No it's not normal! what about Sequential? check it out. Drive at 60mph in 5-6th gear, then floor it and push the lever forward once or pull the left paddle once. See if it works.... BTW, you originally said just sport+ mode ya? it means in sport and efficient mode it's working fine right?
12-10-2014, 07:11 AM | #9 |
Rep 7,885
So are you in any D-Mode when you floor it? D1, D2, or D3?? Even on D1 Mode, when you floor it, the DCT downshifts very fast! If it's not downshifting in any D-Mode then something is wrong. In S-Mode, it's not supposed to downshift for you.
12-10-2014, 03:33 PM | #10 |
Rep 129
Thank you very much for all of your input, I will go pick up my car and test it out see what happen.
13 M5
12-10-2014, 06:15 PM | #12 |
Rep 222
The only way I have found to convey this to the shop foremen (the dude that will make the final decision problem yes/no )on your car is to have someone ride along with you and make a video of what is going on when you are driving. Clearly show yourself putting the car in the modes you are talking about then record the dash with the car not performing as it should. Also easy to post online and let the M5 gurus tell you their thoughts.
Does the dash where the gear indicator is located show 6 S when it won't kick down? |
12-10-2014, 07:03 PM | #13 |
Rep 129
Thank you so much for all of your help, I am an idiot the service department reprogram my car and set the M2 button with 'Sequential mode' which i don't use, that's why it wont' down shift now I set it back to D drive and everything is working good now.
Once again thank you so much for all of your command and help.
13 M5
12-10-2014, 07:15 PM | #14 |
Rep 222
Good to hear you are back to the races! Enjoy your car I have 4.5 months of winter to get through before mine can leave the garage!
12-10-2014, 07:16 PM | #15 | |
Rep 6,067
So looks like you don't read people quotes at all
12-10-2014, 07:34 PM | #16 | |
Waiting for the sun
66
Rep 704
2012 E92 M3- Miss her.
2015 F10 M5- Land yacht, but miss her too! 2016 991.1 GT3- Woohoo! 2018 M240ix- Daily driver. Still Woohoo! |
12-11-2014, 09:44 AM | #20 | |
Rep 7,885
12-11-2014, 11:10 AM | #21 |
Curve Thrasher
623
Rep 3,773
12-11-2014, 03:34 PM | #22 |
Rep 222
I think it is time to have the sticky! You just need to learn how to speak Canadian, eh?
