08-09-2020, 10:59 AM | #1 |
Rep 214
Problems after MPACT: Downpipe? Turbo? Exhaust Manifold?
Here's some background and have any of you experienced the following problem...
A Stage 1 Tune was installed just over a month ago and has been flawless. Yesterday, when driving home from the horribly managed Pocono East MPACT event, I may have damaged my engine, turbos and/or exhaust system. After waiting to enter Pocono Raceway for 3+ hours (~11:30 AM to ~2:30 PM) I left extremely frustrated. After waiting in line for that long, I was still not even close enough to see the main entrance due to hundreds of butt hole drivers, who illegally drove past everyone who were waiting their turn and using proper etiquette. ...during my drive home from MPACT 2020, I should not have done so, but I pushed the car to ~150 mph multiple times as there were spots with absolutely no traffic. Edit: added pics Update: Seems O2 sensor on the US passenger side (top pic) failed or partially blew out. The US driverside (bottom pic) seems to have a clip and is seated into the hole correctly. It is still too hot to know for sure.
Past: 2002 Jeep Grand Cherokee, 2014 BMW 550i MSport, 2005 Jaguar S-Type R, 2000 BMW 540i, 1997 BMW 540i, 1997 WS6 Pontiac Firebird, 1992 Eagle Talon TSI Last edited by 1320racer; 08-18-2020 at 09:20 PM.. Reason: added pics |
08-09-2020, 11:08 AM | #2 |
Rep 55
Not too sure how to help but that mpact line was truly a disaster. Upper management basically politely told me to get lost after i complained about waiting for 4 hours at the entrance.
08-09-2020, 11:17 AM | #3 | |
Rep 214
You actually got in but waited four hours! Wow! What time did you arrive? Did you need to complete COVID-19 forms at the entry gate? That's what someone else posted on FB. If so, they should have set that up to be completed online and BEFORE THE EVENT! It was truly a horrible day for many who spent their hard-earned money and time driving to and from the event!
Past: 2002 Jeep Grand Cherokee, 2014 BMW 550i MSport, 2005 Jaguar S-Type R, 2000 BMW 540i, 1997 BMW 540i, 1997 WS6 Pontiac Firebird, 1992 Eagle Talon TSI Last edited by 1320racer; 08-10-2020 at 06:33 AM.. |
08-09-2020, 06:29 PM | #5 | |
Rep 214
Looks like I need to make a deeper dive and remove the DMEs and the aluminum bridge they are mounted to. Not sure how many bolts hold the aluminum cover over the downpipes—hoping it's not too difficult!
Past: 2002 Jeep Grand Cherokee, 2014 BMW 550i MSport, 2005 Jaguar S-Type R, 2000 BMW 540i, 1997 BMW 540i, 1997 WS6 Pontiac Firebird, 1992 Eagle Talon TSI Last edited by 1320racer; 08-16-2020 at 07:41 AM.. |
08-09-2020, 07:18 PM | #6 |
Rep 78
It's not too bad. I followed this thread to install downpipes:
http://f10.m5post.com/forums/showthread.php?t=1425383 It should help you with how things come apart to get to the downpipes. |
08-09-2020, 07:51 PM | #7 | ||
Rep 55
1320racer136.00 |
08-10-2020, 08:40 AM | #8 | |
Rep 214
Past: 2002 Jeep Grand Cherokee, 2014 BMW 550i MSport, 2005 Jaguar S-Type R, 2000 BMW 540i, 1997 BMW 540i, 1997 WS6 Pontiac Firebird, 1992 Eagle Talon TSI |
94jedi830.00 |
08-14-2020, 09:36 PM | #9 |
Rep 214
Engine bay sounds and smells like there's an exhaust leak. I purchased a Vehicle Service Plan (VSP) through Concord hoping it'd cover major repairs. After reviewing the top-tier Platinum plan that I purchased, it seems gaskets for the exhaust manifolds and/or turbos are covered only if there's an internal failure of the motor or turbo.
I want to go into this repair knowing all I can. What are the best resources providing mechanical 'exploded view' drawings?
08-15-2020, 08:00 AM | #10 | |
Rep 242
1320racer136.00 |
08-16-2020, 07:11 AM | #11 | |
Rep 214
Past: 2002 Jeep Grand Cherokee, 2014 BMW 550i MSport, 2005 Jaguar S-Type R, 2000 BMW 540i, 1997 BMW 540i, 1997 WS6 Pontiac Firebird, 1992 Eagle Talon TSI Last edited by 1320racer; 08-16-2020 at 07:40 AM.. |
08-18-2020, 08:57 PM | #12 |
Rep 214
Anyone had M5 or M6 manifold gasket issues?
This is may be the problem.
I found this info regarding M5s and M6s with manifold leaks. The cause is the exhaust manifold attaching screws have come loose, causing an exhaust leak. Click Here or copy paste this link...https://static.nhtsa.gov/odi/tsbs/20...48251-9999.pdf SUBJECT S63TU Engine: Leaking Exhaust Manifold MODEL F10 (M5 Sedan)Produced to 5/14/2012 F12 (M6 Convertible)Produced to 5/14/2012 F13 (M6 Coupe)Produced to 5/14/2012 SITUATION Noise heard from the engine compartment while the engine is running. It is more pronounced when the engine is under load. PROCEDURE Replace both exhaust manifold to cylinder head gaskets as per Repair Instruction 1814 10 and 18 14 20 Removing and installing/renewing left exhaust manifoldWARRANTY INFORMATION Covered under the terms of the BMW New Vehicle/SAV Limited Warranty
Past: 2002 Jeep Grand Cherokee, 2014 BMW 550i MSport, 2005 Jaguar S-Type R, 2000 BMW 540i, 1997 BMW 540i, 1997 WS6 Pontiac Firebird, 1992 Eagle Talon TSI Last edited by 1320racer; 08-18-2020 at 09:21 PM.. |
