03-03-2015, 10:35 AM | #1 |
Rep 72
M Carbon Ceramic Brake Pads service life~
Yesterday I checked the onboard computer and saw that my brake pads would need to be serviced in 100000km/90000km(aprox. 62000&56000 miles) front/rear. At my first glance it looks fine, but I'm just a little bit curious about why the rear pads wear faster than the front ones. However, after I did a little bit research about CCB on this forum, I found a picture posted by another m4 owner that showed about 250000km left for brake pad!!! I suddenly recalled that I might have seen similar number on my M5 at some point(14 frozen black with CP, CCB, MPE)! I checked my photo albums from three different iPhones and couldn't find any picture evidence about this...how could I not taken a photo for that. I just want to know from fellow members on this forum, what is your current reading from onboard computer regarding to CCB brake pads? Could you recall the initial number when you just took delivery of the car? Iscratched my hair and couldn't remember a thing! I only have less than 10000km (6200miles) on the car, but have tracked the car twice.(at 2000km&5000km right after oil change, small track[3km], about 50~60 laps). Plan on getting some new tires this summer, but not sure how long it will take before I have to replace those pads.......
03-03-2015, 01:50 PM | #2 |
Rep 7,885
Some have said that the CCB's wear out faster than the steels if you track the car quite a bit, but I don't believe that. The CCB pads and rotors at the Performance Center last about 10x longer than the steels on both the M5 and the M4, I have been told.
Either way, it could be the 50-60 laps you have done on the track that is making that number so much lower. From brand new people report 100,000 miles for rotors and 50,000 miles for pads with the CCB's usually.
03-03-2015, 01:58 PM | #3 | |
Rep 10,185
BMW's tech training material says
03-03-2015, 02:31 PM | #4 |
Rep 1,844
I've noticed that my brake lifetime estimates have changed dramatically this winter. Even with snow tires, I have seen the traction control light come on a lot, which is probably the explanation. In particular, this would affect the rears more than the fronts.
I asked a service advisor about it and he said that the system is influenced heavily by whatever has happened recently. He suspected that as we get out of winter that the estimates will stabilize. |
03-03-2015, 04:05 PM | #5 | |
Rep 72
03-03-2015, 04:12 PM | #6 |
Rep 72
03-03-2015, 04:45 PM | #7 |
Rep 6,067
I do not have CCB but I have seen the rear brakes wear more than front in mine too and I think it's because of DSC interference which is more on rear side if you push the car on turns or do hard acceleration frequently ...
03-03-2015, 05:27 PM | #8 | |
Rep 1,171
The DSC is quite intrusive even in M Mode, and to ensure stability on track the DSC is applying the rear brakes a lot in corners to minimize the chance of a spin. When you're comfortable, turn off the DSC completely, and the rear pad wear will become less than the front. Bish |
