F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > best voltage setting for brightness
Extreme Powerhouse
      12-17-2023, 12:33 PM   #1
Sprinterman
Drives: F31 touring
As the title says, can anyone tell me which voltage setting would give the best brightness for led front and rear indicators? The obvious answer is 100 % but that’s not always the case. Mine are currently at 13.7 volts, I’ve no issues with the LEDs whatsoever, just curious as to the correct setting
Martin
      12-17-2023, 09:37 PM   #2
Oksamit78
Oksamit78's Avatar
Drives: E39, F30 & F34
Which app is that?
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12
2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0
2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1
      12-18-2023, 02:25 AM   #3
Sprinterman
Drives: F31 touring
Bimmercode
Martin
Oksamit78271.50
      12-19-2023, 10:16 AM   #4
Oksamit78
Oksamit78's Avatar
Originally Posted by Sprinterman View Post
Bimmercode
The screens you show are from 3062/3063 or other?
      12-20-2023, 05:25 AM   #5
Sprinterman
Drives: F31 touring
3062 rear electronic module
Martin
      12-20-2023, 08:36 AM   #6
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
My educated guess (I'm an electrical engineer) is that the default setting limits the voltage to 13.7v so that the maximum 14.5v or so output from the alternator won't damage the bulbs.
Oksamit78271.50
      12-20-2023, 03:14 PM   #7
Sprinterman
Drives: F31 touring
So even if I have the setting at 100% 0x64 it won’t increase the brightness as the default is 13.7. So it will be the same in either setting, i understand, Thankyou for the higher voltage setting warning
Martin
      03-11-2024, 06:13 AM   #8
Sprinterman
Drives: F31 touring
So I did a few tests, night time coding to see the effects of different voltages. 100% definitely throws out less light then 13.7 V. You would think 100% is exactly what it means, but the difference when you use 13.7 V is pretty significant. So I’ve used 13.7V in every LED I installed, apart from the ones which will only allow 100%, the front fogs I coded to 13.7V and it also puts out a much greater light then the 100% setting. Also there is no flickering, but I wouldn’t go to 14V or above as billfitz said, as there is a risk the LEDS will burn out or not last very long. Mine have been in for almost 2 years with no issues
Martin
_ObiJon200.00
f30post
