12-22-2016, 02:48 PM | #1 |
Rep 191
Does anybody on here run their m5's with e85?
If so, what are the pro's and cons? What map do you run? How much e85 do you add per tank? What supporting mods are absolutely required? I keep reading about people running it on the n/s55's but haven't really heard anybody running it in the n/s63's. |
12-22-2016, 03:45 PM | #2 |
Rep 715
You can run up to 25-30% e85 without modifications. Which is 3-5 gallons on a full tank of 91+.
On a side note, you should monitor your fuel trims to make sure they are safe.
Jhenka31.00 |
12-22-2016, 06:20 PM | #4 |
Rep 843
Dumb question, you need meth and full tune to properly run E85? Or can you do JB4+BCM with meth and run. E85?
12-22-2016, 07:19 PM | #5 |
Rep 881
I run ~3 gallons/tank of 91, even before I got my tune.
2014 "AW/SO"me M5
12-22-2016, 09:16 PM | #6 |
Hide! My wife's coming!
812
Rep 2,816
I consistently ran about 3 gallons of e85 with a full tank of 93. FBO M5 with flash tune.
12-23-2016, 01:43 PM | #9 | |
Joint Chiefs of Staff
24190
Rep 190,804
You can probably start with a very low mix, datalog check your fuel trims and adjust as needed
Jhenka31.00 |
12-23-2016, 02:25 PM | #10 |
Rep 587
in my car i've literally put about 5-6 gall's e85 in everytime i fill up cause its very easy for me to get!
no dyno to back up but the car was nite/day fassster ! downside was by half tank its was gone and as stated mpg was affected a lil nothing to stop me from doing it ! Ran like this for well over 2 years w out an issue , had a jb4 , rpi scoops , bms drop ins car was a beast ! my 16 is still bone stock but im sure ill use it again |
04-27-2017, 06:33 PM | #12 |
Rep 260
04-27-2017, 06:34 PM | #13 | |
Rep 260
04-27-2017, 07:42 PM | #14 |
Rep 402
it maxed my fuel trims, def don't recommend without a tune, the but dyno can be very deceptive snd i suggest not doing anything without monitoring logs
04-27-2017, 08:28 PM | #15 |
Rep 2,062
It maxed my trims as well, which in turn I've bumped up my FOL to 80 on my JB4 but I still won't run it anymore until I'm either running meth at the same time and/or we get an E85 pump flash like the N54 guys have.
04-27-2017, 09:20 PM | #16 | ||
812
Rep 2,816
Terry with BMS recommends that you pair the JB4 with a backend flash to make the necessary adjustments needed to support the JB4 and make the most efficient power.
04-27-2017, 09:43 PM | #17 |
Rep 402
i think it maxes the the trims on the vast majority of non competition pkg cars, the owners all think it "feels" faster but i think its dangerous. If you want more octane mix a little race gas or use octane booster, at least that won't max the trims.
04-28-2017, 06:14 AM | #18 |
Rep 788
Yep, a lean mxer may give the best power BUT is very dangerous, miss fires and detenations will melt the pistons or break the ring land
04-28-2017, 06:54 AM | #19 | |
Rep 8,083
your car was also always in limp dick mode.... |
04-28-2017, 06:11 PM | #20 |
Rep 2,039
If pre-LCI you will starve the engine of fuel with too much e85... You would need a tune or meth. LCI models have slightly improved fuel management but it's still better to have a tune.
