04-13-2014, 05:48 PM | #1 |
Rep 3,688
Drives: 2021 Supra 3.0 (Past: 2015 M23
GoPro placement
Where is the best place to put a GoPro camera on your car and which mount works best? Goose neck, suction cup.....
Headed to Europe for European Delivery and I wanna take full advantage of my go pro (Hero3)
04-14-2014, 10:47 AM | #4 |
Rep 3,688
which mount do you guys use? I just have the camera no case or anything
04-14-2014, 12:40 PM | #5 |
Curve Thrasher
623
Rep 3,773
Ok, your gonna have to go to best buy or order from amazon to get the case. I know there are other places who carries the attachments but cant think of any. It has an attachment that clips from the camera case to the clip that will attach on the dash or where ever you put it.
Country run |
04-14-2014, 01:07 PM | #6 | |
Rep 3,688
http://www.amazon.com/Carbon-Design-...498517&sr=1-10 Weird I can't find the regular clear protective cases... Then the mount would look something like this? http://gopro.com/camera-mounts/remov...trument-mounts
04-14-2014, 05:16 PM | #7 |
Rep 1,264
Thats like a sticker... I would just go to BestBuy and pick up the suction cup mount one. I have it, works well. I like in car upside down mounted on sunroof.
2010|335i|LMB|E92|6MT|MSport|Logic7|335is Clutch|AE Performance|BMS|Walbro|VRSF 7"| 149.7mph NFZ AZ 1/2mi
1992|Pontiac Firebird|Mild 355ci|T56| -I will look on your treasures, gypsy. Is this understood?- |
04-14-2014, 05:25 PM | #8 |
Rep 1,134
Drives: '07 M Roadster
If you want the camera in the car get the skeleton case so that the mic isn't covered up. A suction cup mount in the windshield is also a good place to put it and the gopro suction cups are solid.
04-14-2014, 05:48 PM | #9 |
Rep 432
I have used the suction cup on the front driver door for a video. Worked well, except the wind noise. If I were to do it again I'd do the same spot, but with a remote mic on the back bumper to get the exhaust note.
04-14-2014, 06:28 PM | #10 |
Rep 4,959
I use the GoPro car mount.
For exhaust videos, I mount the camera on the trunk.
Current: '23 G20 M Sport 330i
Current: '20 X253 GLC300 SUV Gone: '20 W205 C43 Sedan Gone: '18 W205 C43 Sedan Gone: '13 W204 C63 Sedan |
04-14-2014, 07:55 PM | #11 |
Rep 10,587
I've done a few different locations
on trunk pointing rear and down also interior on the rear glass with different angles here:
04-14-2014, 08:44 PM | #12 |
Rep 3,870
OP:
Go Pro can be placed anywhere you want... Heck you can put it as a hood ornament and it's perfectly fine! They stick very well, as long as you have a relatively flat and clean surface. Try to vary the places you put it, because it can become very boring to watch the footage from the exact same place for hours... I hope you will post your ED photos
04-16-2014, 12:54 PM | #13 | |
Rep 3,688
I should be good with this skeleton housing http://www.amazon.com/GoPro-AHDKH-30...eleton+housing and this suction cup mount: http://www.amazon.com/GoPro-AUCMT-30...ro+suction+cup any other accessories you recommend?
04-16-2014, 12:55 PM | #14 | |
Rep 3,688
04-16-2014, 12:57 PM | #15 | |
Rep 3,688
Here's my failed attempt to record in a 996. I will cut the music off next time.
04-17-2014, 02:34 PM | #16 | |
Rep 1,134
I would also recommend getting more batteries. The batteries don't last too long if you're trying to record a lot. Depending on your budget the backpack and another internal battery would be good. I did 6 laps at Nurburgring with 1 stock battery and the backpack and it barely lasted the whole time shooting HD and with wifi on for some of it. You might be able to use a USB cable to provide power, but I've never tried that.
04-19-2014, 04:53 PM | #17 | |
Curve Thrasher
623
Rep 3,773
Don't want my mug on any vids. Dash or outside for me..
Country run |
05-20-2014, 06:09 PM | #18 |
Rep 3,688
Ended up with this thinking of getting a suction cup as well
Tags |
camera, european delivery, gopro, mount |
