02-28-2018, 09:01 AM | #1 |
Mark
11
Rep 9
Faulty Door Lock / Comfort Access?
I've recently been having some problems with the locking and unlocking of my car (F10 M5), and although I've read another similar thread, having played around with a number of fuses, perhaps my problem isn't the same.
Basically my car has been having intermittent problems with the remote locking and unlocking. It seems to have a mind of its own! I can approach the car with my key in my hand and the car decides to unlock itself, even when not pressing the remote button or pulling the handle (comfort access). Sometimes I can approach the car, try to unlock it with the key fob, and it won't open. There's times when I lock the car with the fob, and immediately it unlocks itself. There's even times when the car wont unlock via the fob or through comfort. I'm sure all of this malfunctioning is the reason why I'm getting warnings on my dash that the battery is draining while stationery! I've looked at similar posts, and it's been suggested that this lot could all be down to the comfort access, and through pulling Fuse 36 this will cut out the comfort access, therefore stopping the problematic element and stop draining the battery. On my car Fuse 36 is for washer fluid, so I've pulled all fuses part from 2 and 8 (difficult to access), and have not been able to isolate the comfort access. Has anyone had similar problems? Any ideas what this erratic locking, not locking, battery draining issue is? ultimately I might need to take the car to BMW to rectify, however if the issue may just be the simple replacement of a fuse, I don't look forward to their charging me a couple hundred pounds for their troubles. Your advice would be much appreciated. Thanks, Mark Last edited by mwnbr; 02-28-2018 at 09:06 AM.. Reason: update |
02-28-2018, 09:26 AM | #2 |
Rep 125
I did (do) on my X5 50i (2011). When purchased, it had battery issues and the driver handle was hot to the touch. I replaced the handle with a used one and the battery issue went away, but CA only works with hatch and ignition. I have had discussions with BMW and one advisor stated that it's almost certainly still a handle. I guess they short out internally.
02-28-2018, 09:47 AM | #3 |
Rep 1,107
Usually when guys have had issues with their comfort access, it's been a faulty door handle. Good luck
xander_g1009.00 |
03-01-2018, 07:19 PM | #6 |
Rep 149
Mine has started to lock me in and I have to use the central unlock button to get out. SA said its the door lock actuator going out but I also have intermittent touch to lock issues...
Other toys
'07-997 Turbo....EVOMS 580..AWE exhaust...champion intercoolers..champion springs. '91-964 Turbo K27 Hf turbo...Techart Exhaust...etc, etc |
03-02-2018, 05:33 AM | #7 |
Mark
11
Rep 9
Thanks for the responses. Curious that a few of you suggest it could be the door handle in need of replacement. I'd not seen this suggested on any other similar related topics elsewhere.
I don'k know if my original post mislead anyone. There are times when I approach the car and it's fine, and then upon pulling the handle the car will unlock; the comfort access works. Instead the whole issue seems to be due to the proximity of the car fob to the car. There's also times when the car has been locked by the fob, and I can hear continuous noises from the car of locking sounds, eventhough the car is locked. I'm sure it's this that might be draining the battery. Looks like I need to book the car in with BMW. |
03-02-2018, 04:30 PM | #8 |
Rep 385
The reason why many respondents have mentioned the door handle being at fault is because it's the handle that instigates the lock/unlock request (assuming you're not pushing the key fob buttons). When you touch the lock or unlock part of the door handle, the car then sends a message to the fob looking for a correct response. If the fob is not found, you can neither lock or unlock using the door handle.
So the handle is probably triggering frequently by itself, but you can only notice it when your fob is in range. You can play with this by taking the fob out of range, covering with tin foil (I read this but haven't tried it to see if it works), or simply taking the battery out of it. You may have been thinking that its the fob buttons that are stuck, which is possible, but unlikely, because this would kill the fob battery pretty quickly. If you have a second fob, you should see the same spontaneous lock/unlock triggering with both fobs if the door handle is at fault. The handles are a little twitchy. I sometimes see lock or unlock trigger while I am rinsing the car door while washing the car. I leave the fob in the car or take it into the house instead of leaving it nearby in the garage to avoid this happening. |
BMWM5NYC496.00 3rdCoastBMW18.00 |
03-07-2018, 06:05 PM | #10 |
Rep 673
OP, I'm having the same issue. The M5 will unlock automatically as I approach the car. It only does this when I approach the driver side door. Once I step out of the car even when the car is unlocked, I still hear the sound of the car trying to keep unlocking. I also get the message battery is low.
It all started awhile ago when my driver door comfort access stopped working by putting my hand in the sensor area. I haven't had it checked yet. Please keep us posted to what was the issue. |
03-12-2018, 05:23 AM | #11 |
Mark
11
Rep 9
Well I've not yet had the visit to the service centre for diagnosis and repair. How and why I don't know but a couple of days after fuse removal and replacement the car has started behaving itself. There's been no new parts or reprogramming, and even the fuse replacement was with the same fuses. So could the problem have been a loose fuse? Who knows. But by identifying the fuses responsible for door locking systems, removal and replacement, that so far appears to have cured the problem. It's now been two weeks prob;em free so hopefully it remains that way.
03-15-2018, 12:20 AM | #12 | |
Rep 673
06-07-2018, 03:33 AM | #13 | |
Rep 14
Perhaps I will try unplugging and plugging all fuses back to see if this also works for me Can you please advise if the issue re-occurred again? Thanks |
06-08-2018, 08:25 AM | #14 |
Rep 1,123
The easy way to diagnose is to remove the suspected door handle. There will be two plugs. The larger plug is the one you'll disconnect. Now put the handle back in. If the car quits acting crazy....you've found your door handle issue.
I left my back R door handle unplugged for a month while waiting for a new handle. If you never unlock the door from there you could technically just leave it like that. |
07-11-2018, 05:34 PM | #15 |
Rep 1
CA,, i have got the same problem but its not only 1 handle.. its 3 handles how come they all are faulty then? i unplugged 2 handles and another one seems to start playing up...
07-16-2018, 11:33 AM | #16 |
Rep 1,123
If it's still doing this with 3 handles 'disconnected'....it's probably not the handles in your case......unless it's the 4th handle. LOL!
07-16-2018, 04:31 PM | #17 |
Rep 385
07-31-2018, 10:03 AM | #18 |
Rep 1,359
My car has began doing exactly the things described by the OP here. It began with driver's door not working to lock the car on comfort access. Then the unlock would only work if I physically pulled the handle forward then released and pulled it again (first pull unlocked, second pull actually allowed door to open). On Friday I experienced the continuous motor noise which sounds ded like it was coming from divers rear door. Saturday the car wouldn't unlock with comfort access or fob and I had to use the key (how quaint). Then later that day the car unlocked itself as I approached with the key in my hand but I didn't depress any buttons. I will show this thread to my dealer and will post my issue once it's resolved.
09-18-2018, 07:19 AM | #19 |
Rep 4
hey new to the forums, just picked up an m6 GC. Has a similar issue. Audiable unlocking noise from the fuel filler flap. Comfort access works when opening the handle most of the time, just locking it on the sensor is very intermittant. Also showing warning for battery discharge when stationary, also have the tyre pressure sensor warning saying faulty, however shop says there are no readings being taken. Checked battery and it's still got 12A left - any other possible causes other than a singular handle?
09-18-2018, 04:23 PM | #20 |
Rep 385
A good shop will know how to use ista+ / Rheingold to check for handle triggers. You can do this at home as well if you took up. The battery is probably running down from all the triggers and the car not going to sleep. Think you need to find a better shop.
09-19-2018, 12:43 PM | #21 |
Rep 19,565
Slightly off the subject but in the UK I think comfort access on an M5 is a bad idea.The crim with lap top and magnetic plate will have your motor open and be away with your pride and joy if you don't put foil around your opener(s) at night or place them in a metal box.Anyway good luck with the fixing,seems the door handle is the main 'suspect'...
09-24-2018, 06:27 PM | #22 |
Rep 1,359
My driver's door handle was replaced under warranty. Dealer also replaced the battery without question as the stored fault codes showed the battery had discharged below it's operating minimum on multiple occasions. Comfort access is now working perfectly. I have had 2 further battery discharge warnings though which I will keep an eye on.
Tags |
lock faulty comfort access battery |
