09-11-2022, 11:31 AM | #1 |
Rep 28
Occassional misfire
Hi all,
I have encountered a misfiring issue with the M5 recently. First time was over 1 month ago (c. 500 miles), it suddently started misfiring when engine was cold and driving in traffic (no pulls or anything). Got a CEL/Drivetrain malfunction but quickly restarted the car at the traffic light and thereafter the CEL was gone but still light misfiring. When I got home I didn't get any codes with my (basic) scanner. Watched it closely thereafter but in the weeks following (c. 500 miles) no misfiring whatsoever, until it was back last week. Now I get the following codes: 152D08 : super knocking 152108 : super knocking injection cut cylinder 1 Symptoms/context: - Spark plugs & coils were changed c. 2500 miles ago (along with injectors, high pressure fuel pumps, lambda sensors and software update) - Have quicky replaced the coil on cylinder #1 again, didn't dare to do the spark plug myself but this hasn't had any impact - The misfires are not consistent, not every trip and not always at the same moment. Only when accelerating, but not always - I run 102 octane petrol - Car is completely stock Any one any ideas? Thanks a lot! Best, Joep |
09-11-2022, 03:49 PM | #2 | |
Rep 19,556
09-12-2022, 12:03 AM | #3 |
Rep 28
Hi Rick,
No, I’m in NL so its not Aral. It is a local pump that provides the 102. I have run on 102 for 7k miles without issues and recently also had a tank of 95 since nothing else available, it also happened then. So I don’t think it is the fuel. Best, Joep |
M5Rick60089.00 |
09-12-2022, 05:54 AM | #4 |
Rep 19,556
It could be a failing spark plug, unlikely on new plugs but not unknown for it to happen, that's why I had a plug change at a BMW dealer with the 2 year parts/labour guarantee.
10-13-2022, 09:59 AM | #5 |
Rep 28
Hi guys,
As an update - the car has been with the shop for a few weeks now. They had quite a backlog so took a while before they could start working on it. Status is that mechanically everything seems OK (compression, cylinder leak testing, etc.) but when the engine warms up the misfiring starts. Also checked spark plugs, coil packs, etc. but that didn't solve it yet. They are now planning to switch the DMUs to see whether the issue also changes with it. Anyone else suggestions what it could be? Thanks a lot! Best, Joep |
10-23-2022, 12:00 PM | #7 |
Rep 538
Do you know what wiring?
Sorry I didn't see this thread earlier to contribute. I had a similar issue with a loose DME ground wire. I know of someone else on here who's has the same. |
10-24-2022, 02:38 PM | #8 |
Rep 28
Hi Raz,
Was somewhere in the wiring harness, not close to the DME (what I understood from the shop). Mass/ground wires seem to be a misfiring cause, they checked all ground wires on mine Best, Joep |
