      09-15-2022, 09:27 PM   #1
izaazk
Drives: 2013 335i
Cylinder 4 Misfire - New coils / plugs / fuel injector
hello -
I am trying to figure this misfire out... bought the car 2 days ago and drove fine and we pushed it hard during test drive. Drove fine for 10 hours straight then when we downshifted, it triggered a misfire and Drive Train malfunction.
I replaced all 8 spark plugs and ignition coils with oem BOSCH and replaced 1 fuel injector on cylinder 4.
Cylinder 4 seems to constantly misfire as soon as the engine starts you can hear it. (Combustion misfire code)
Compression test is the only thing i havnt done yet... any ideas here or am i F**KED after just buying the car
      09-16-2022, 03:24 AM   #2
Sorry to hear that, I'd do the compression test to get a fuller picture.
      09-16-2022, 03:36 PM   #3
Kamate
Drives: BMW m6
You didn’t say if you coded the new injector. But if you didn’t, you have to code it. Other than that, do the compression test like Rick said.
      09-16-2022, 07:05 PM   #4
izaazk
Drives: 2013 335i
Compression test came out okay all 1-4 cylinders are 170-180 in compresssion
We did code the new injector
We are doing injector actuation test and turning off cylinders 1,3,4 all cause they engine to stumble but 2 doesn't do anything so I wonder if it's something
