05-22-2014, 12:35 PM | #1 |
Rep 792
BMS STAGE 1 TUNE W/ METH integration F13 M6 11.0 128MPH
Was a ruff day! track lights / power went out when we got there and of all things a hot hot day of 90 temps.
Anyway finally got my 60 ft where I want it but as for track times everyone was complaining how there times were off. My first run I just gased it like normal and got a 11.8 @ 124.... I was mind boggled for the last time I was running 11.3's @ 128 just gasing it with a lot less power. Any way was hoping to get tens but that wasn't the case. Planning to go back next week and maybe another track to compare. But i did get my 60ft at a best 1.69 and average of 1.7's, that the hardest part. Last edited by m6beast; 05-22-2014 at 12:52 PM.. |
05-22-2014, 12:55 PM | #2 |
Rep 4,106
Awesome dude. What tires did you use and launch technique?
05-22-2014, 01:30 PM | #3 |
Rep 792
I used TOYO R888's 285 35 20's on my stock wheels
25 PSI I've tried everything in the past just gassing it at the light, launch control which is inconsistent, breaking and giving a little bit of gas just so the power doesn't get cut. But finally and I can say finally I decided to do burn out mode and it wa perfect. Now just have to time it perfect because it has a slight delay. But no dry hop, spinning or anything it was perfect and consistent! |
05-22-2014, 01:31 PM | #4 |
Rep 806
Awesome!
Your 60 is about the best I see these cars doing. I can't wait to get out. Summit screwed up my order and sent me one 20" and one 19" Drag radial. I don't think I will be quite as fast with my race cats. You need a nice tail wind to push you over. lol
05-22-2014, 01:39 PM | #5 |
Rep 4,106
So you hold the M6 record. Make sure you post it on drag times. We need to keep track of the quick ones.
Check out my video in my signature. Ran a 11.07 in a M5 with no meth. 500 lbs heavier than yours, but I think I can get it into 10's. It's very hard to launch and move the weight down the track though. I use BMS tune as well.
05-22-2014, 01:41 PM | #6 |
Rep 806
So you were running meth on these runs?
05-22-2014, 01:41 PM | #7 |
Rep 4,106
05-22-2014, 01:46 PM | #8 | |
Rep 4,106
05-22-2014, 01:59 PM | #11 |
Rep 806
You mean the down shift paddle? So stomp gas and down shift? That would be a lot more slick than my method.
05-22-2014, 02:00 PM | #12 |
Rep 4,106
I still dont get how that works.
05-22-2014, 02:01 PM | #13 |
Rep 792
No just sit at the light and just stomp on the gas while in first gear.
Also all my settings were on sport plus except my suspension I set at comfort and traction control off |
05-22-2014, 02:10 PM | #14 |
Rep 4,106
Tried that and the car spun its tires and hit the limiter.
05-22-2014, 02:22 PM | #15 | |
Rep 792
I have 305's 21's and have no traction in first gear or second gear. don't even consider racing any one unless I have my drag radials, unless if we do a 50-60 roll. |
05-23-2014, 09:43 AM | #18 |
Rep 4,106
I am going back out June 13th. Better run a 10
05-23-2014, 10:49 AM | #19 |
Rep 792
http://youtu.be/DAkWWbJWW9o
Sorry for the crappy cell phone video or drag times,they do grudge matches here so they show no times. Forgot my camera at home but planning to go back next week. Hopefully I can break 11's too! This is against a F10 M5 mild mods. Stock DP, stock DME |
05-23-2014, 12:15 PM | #21 |
Rep 792
Yes I have back in the day didn't care for it too much. I like Rockingham and Darlington feel more comfortable where Zmax I felt too commercialized. Beautiful track that's for sure.
Plan to go to Fayetteville and run out there in the next couple of weeks. Ill keep you guys in the loop. |
05-23-2014, 01:07 PM | #22 | |
Rep 745
Drives: '14 M5 CP & '62 corvette
2014 ///M5 Singapore Grey Metallic, Black Extended Merino, Anthracite Wood Trim, Comp Pkg, Driver Assistance Plus, Exec Pkg, Lighting Pkg, B&O, 343M Wheels (11.597 @ 122.44MPH)
Mods: Gloss Black Wheels, 35% 3M Tint, IND Gloss Black (LCI Grilles, Side Markers, Rear Emblem) IND M5 Floor Mats, RKP (McRae Splitters & Rear Diffuser), Passport 9500ci, Suntek PPF-C, M Door Projectors 1962 Corvette Convertible Red/Black (Gone:'11 750Li, '09 Z06, '08 550i) |
