09-02-2022, 07:18 PM | #1 |
Rep 74
Dealer screwed up DCT service..
Hi, all. Have an issue and figured I'd come here for advice Took my car (2016 M5 with 56k miles) into the dealer (Patrick BMW in Schaumburg, IL) to get a DCT drain and fill with filter done yesterday. Got the inspection video today and tech states that he only used 1 liter of fluid… okay.
Called my service advisor and he said they actually used 1.9L and that I was only billed for 1. After doing some of my own research and calling other places, looks like you drain out about 4-5L just from the drain plug alone. They're now telling me that their system says it only needs 1.9L. That quantity may be true but for the true 6 speed manual trans and not the DCT and that's where I'm assuming the confusion is.. They still have the car and they're telling me they'll verify in the morning before I pick it up but can anyone actually verify? All vendors for kits sell 4-5 bottles of fluid and every tutorial I'm reading/watching uses the same amount as well but I'm being told otherwise by the dealer. Not really sure what to do at this point. SA claims they use ISTA to verify the level after I had asked them but one thing I don't like about dealers is that there's always a disconnect between the advisors and techs, and advisors just assume something was done rather than actually confirm. I obviously don't want to risk frying my trans and end up having to do a rebuild. Just looking for some sort of confirmation at this point I guess. Any input as to what to do would be greatly appreciated.
2016 BMW M5
2019 BMW X5-This will hit 10's in the 1/4 mile |
09-02-2022, 07:27 PM | #2 |
Rep 539
Something is definitely not done right. I'm surprised the dealer agreed to do this on a "lifetime" fluid.
When I had mine done the shop used ~6 liters with a new pan, gaskets, filter, everything. The kits online have 7 liters, which makes sense. It's possible that your dealer drained from the overfill plug? In any case, I'd take/tow it asap to a shop that knows what they're doing. Take the loss and move on, that's why everyone says to avoid the dealers. |
09-02-2022, 09:15 PM | #3 |
Rep 892
Well there's two filters and the pan has to be replaced when doing the second filter. Mine took ~6.5 liters (with dropping pan) with most of that going in during the fill procedure. They're not doing the fill procedure correctly. Request a more knowledgeable technician or advisor.
CURRENT ll F10 M5 l E85 Z4MR l I01 i3 REX SOLD ll E70 X5M l E85 Z4MR VF570 l E36/7 Z3MR l E36 328i |
09-02-2022, 09:53 PM | #4 |
Rep 1,247
You posted on FB, I am pretty sure they did the diff fluid. BMW won't do the DCT as per BMW is lifetime fluid and they will only do it if you damage something. Get the dealer service receipt and see what they are actually charging you for
M5Rick60969.00 |
09-02-2022, 10:06 PM | #5 |
Rep 74
Here's the receipt.. they offered the rear diff, I told them not to since I was going to tackle that myself when i put my exhaust on
2016 BMW M5
09-02-2022, 10:13 PM | #6 |
Rep 1,247
I saw what you posted on the FB, they replaced the side filter and filled up what came out. So they really charged you what they did. They didn't replace the pan and the bottom filter.
09-02-2022, 10:19 PM | #7 | |
Rep 892
09-02-2022, 10:21 PM | #8 | ||
Rep 1,247
And pretty much filled what was in the filter. No where they claimed they dropped the pan and replaced the pan and pump filter. |
09-02-2022, 10:36 PM | #9 | |||
Rep 892
09-02-2022, 11:31 PM | #10 | |
Rep 1,247
09-03-2022, 02:27 PM | #11 |
Rep 74
Update: tech confirmed that he did drain the pan from the plug and only filled with the 1.9L. The dealer admitted fault and redid the service, draining whatever was in there and filling it up again, which this time took 4.5L of fluid. Passed the function tests on ISTA and finally got a good measurement reading.
It was supposed to be a drain and fill from the beginning with the filter being changed. The tech was given incorrect information and that's what led to the screw up. Best part is, they didn't up charge me for their mistake like how some dealers usually do, so I basically got a drain and fill with a filter for $500. Will be picking up the car in the next hour or so, I'll update you guys in a bit
2016 BMW M5
09-03-2022, 05:28 PM | #12 |
Rep 1,247
Great news, imagine that was someone who didn't have any idea. Would have killed the DCT and dealer would have blamed someone else
09-03-2022, 08:51 PM | #13 | |
Rep 1,261
