      08-15-2016, 01:27 AM   #1
dk79
Drives: 2018 F90 M5 Marina bay blue
Question jb stage 1 gains?
1) i want to know how does the car behaves with jb stage tune for m5?
2) are there any drive issues?
3) any cel?
4) abrupt throttle changes?
5) with stock 4 psi boost increase bms has posted dyno numbers with about 70whp increase while they advertise only 30-50whp, don't understand this?
6) considering stock 0 to 60 time is 3.7 and 1/4 11.8-11.9 sec what should i expect in terms of improvement with jb stage 1 at 4 psi?
i was thinking about ess flash tune but their dyno numbers show 15% increased hp over stock, jb stage 1 with 4 psi is 12% over stock so the difference is only 3% between ess and jb stage 1, ess being higher.
      08-15-2016, 01:40 AM   #2
ur20v
Just go straight to JB4 and BCM, you can then change the map to mood and situation plus any changes in mods as you do them...
      08-15-2016, 03:14 AM   #3
dk79
Jb4 is pretty advance install so I will stick with stage 1 for now and maybe go with jb4 or flash tune. My ess flash tune in my 650xi was a champ stock 1/4 12.8 at 106mph, stage1 flash 1/4 mile 11.8 at 118 at da 3300.
      08-15-2016, 12:17 PM   #4
TheHouseWon
TheHouseWon's Avatar
644
Drives: 2013 M5
I would go with BCM, too.
      08-16-2016, 04:20 PM   #5
LI-M5
Drives: 2016 M5
if your looking for the 1st step , i'd say just do the jb4 alone !
the bcm is for a more perf orientated modder , in answer to your Q's the jb4 alone will basically give you a shit ton more power across the range and you will love every sec of it ! you can alway add a bcm at anytime !
i may be mistaken here but i was under the impression it's 3.5 lbs boost and anywhere from 70-80 hp
      08-21-2016, 02:39 PM   #6
rif75
France
64
Drives: BMW M4 LCI ZCP and BMW M5 f10
I'm lost, for some, the JB4 with BCM is a waste of money since if you don't have a ZCP, you re pretty limited to the first map,eventually with the 2nd but some issues in their log so since I'm considering a JB4, I'm asking the same...
BMW M5 ZCP and M4 ZCP. BMW 540i G30 stage 2 with KW street confort, Wagner DP, Remus catback, M sport brakes 395mm front and 385mm rear. MHD tune.
      08-21-2016, 06:40 PM   #7
platinum903
Drives: F90 M5, F85 X5M, G05 X5
What is BCM?
      08-21-2016, 07:10 PM   #8
ur20v
Only some non-CP cars can't run map 2as they don't have enough room to run map 2 and keep the AFR in check, you just need to log and check before its a guarranty thats all.
I now run meth/water injection so use map 3.
