08-24-2016, 01:20 PM | #1 |
Rep 1,123
How much oil is enough??
Hi All! I just performed an oil change (easy peazy). Added 9 qts of oil went for a drive then performed a measurement on level ground and the mark showed up exactly half way between min and max. So I added a 1/2 qt but it still shows at the half way mark. Has anyone put 10 qts in their M5? I don't want to overfill, but the Idrive measure deal is still not at the max???
08-25-2016, 06:36 AM | #2 |
Rep 388
oil
Don't overfill.
Check owners manual ( easiest ) M cars tend to take more oil that their non M counterparts. I do in some cases out of being curious will drain the oil and physically measure the amount dropped . This gives me a very good idea what should be in it ( engine ) before filling again. Mind you I have not gotten to that point yet since all of my maintenance are still being done by the dealer. |
08-25-2016, 12:57 PM | #3 |
Rep 388
8.5 quarts is the recommended after Oil Filter removal and change.
21' Bentley Bentayga SPEED
21' BMW Alpina XB7 22' Cadillac Escalade ESV 22' Porsche Cayenne Turbo 24' Porsche GT4RS on order |
08-25-2016, 01:39 PM | #4 |
Rep 1,123
I read 8.5 liters. Wound up at a final 8.9 liters (after removing 300ml) Now the oil meter is slightly under max. I think this is where I'll leave things. While going thru this process I noted that there's also 1.5 liters of oil in the oil cooler. Does this drain?
