04-19-2019, 01:05 PM | #1 |
Rep 132
What to look out for?
Hi,
I have decided I want another M5, I am looking at a 2012 with 60k on the clock and would love to know what to look out for when I view the car. I had an E39 M5 and miss it every day, had loads of others too, 335i, 535i E39, 745I, 840CI and a couple more, been driving a 2009 Merc CL500 AMG for the last two and a half years but want the M back. Any help much appreciated. thanks |
04-19-2019, 03:06 PM | #2 |
Rep 223
Service history is the most imp one to look out for. Always good to take it to your mechanic and have them life it up and check suspension, steering, belts hoses oil leaks etc. good luck.
04-19-2019, 10:41 PM | #4 | |
Rep 179
04-20-2019, 03:14 AM | #5 |
Rep 19,550
The same as to what I have mentioned before applies to models above '12 as the engines are exactly the same for even the often mentioned 'lci' models that have exactly the same non forged rod bearings as the 11-13 ones.Makes no difference as they need to be checked also for peace of mind.
04-20-2019, 08:23 AM | #6 |
Rep 132
Hi,
Thanks for all your reply's, much appreciated. I take it there's an issue with rod bearing in this engine? I am aware of the oil consumption on certain engines and i'm guessing its just your luck , however I have had a service history report and it has had 8 services all by BMW, also to note on the bulletin was that it had been into BMW for a few top ups around 3k miles apart in its earlier days. I take it this is a lifetime issue? also the turbo lines have been repaired around 10k miles ago. car has new brakes all round and tyres so no issues there. i'm not overly concerned with basic repairs as I usually do these myself and I also have a great mechanic if required. The engine would be the worry but i'm sure there are thousands around with no issues. the internet always shows up the problematic ones which gets you thinking.. Are the early models that bad I should steer clear? 66k is fairly low mileage I would have thought, my old E39 had 148k on her when I sold and was still pulling strong. thanks again guys!! |
04-21-2019, 01:12 PM | #7 |
Rep 179
You only hear rod issues when there is a problem. There are countless number of other things that could go wrong with your car and if you start thinking about it, you can't sleep at night. Buy one that suits your budget, do preventive maintenance and enjoy it. You don't hear about rod bearings as much compared to E60 E90 platform if it makes you feel any better
04-21-2019, 02:43 PM | #8 |
Rep 132
yeah, I think if you looked on the forums and read through all the posts you would never buy a car. I had a 996 911 and after two years found out about a potentially catastrophic engine issue, most people walked away but I never knew about it and my car was excellent. I usually just ask about the main issues and try to get a feel for what to look for when I view so thanks for all your input. the car has 4 previous owners which is a few I guess for a 7 year old car but most 2011-2013 models have this that are for sale at the moment in the u.k and also some newer ones. I usually change every two years and sometimes earlier so I guess there could be plenty of people like me out there. think I will take the 300 mile trip to have a look and if I like it have an inspection carried out.
thanks |
pcohen15379.50 |
04-21-2019, 10:39 PM | #9 | |
Rep 533
1972 Bavaria> 1973 3.0Si> 2013 328i> 2009 E92 M3> 2013 F10 M5: Singapore Gray over Sakhir Orange, Executive, Driving Assistance, B&O
04-23-2019, 04:14 AM | #10 | |
Rep 19,550
04-23-2019, 01:07 PM | #11 |
Rep 132
04-25-2019, 02:30 PM | #12 |
Rep 132
How do these options look chaps?
01CA Selection of COP relevant vehicles 01CC Auto start/stop function 01CD Brake Energy Regeneration 0223Electronic Damper Control (EDC) 0245Steering wheel column adjustment,electr. 02MK M double-clutch transmiss. w/Drivelogic 02NZ BMW LA wheel, M Double Spoke 343 02PA Wheel bolt retainer 02VB Tire pressure display 0302 Alarm system 0322 Comfort access 0403Glass roof, electrical 0423Floor mats, velours 0428Warning triangle and first aid kit 0430Interior/outside mirror with auto dip 0431Interior mirror with automatic-dip 0441 Smoker package 0488Lumbar support, driver and passenger 0494Seat heating driver/passenger 04L9Interior moldings Alu Trace 04MA M multifunction seat 04NB Autom. climate control with 4-zone ctrl 04UR Ambient interior lighting 0502Headlight cleaning system 0508Park Distance Control (PDC) 0522 Xenon Light 0524 Adaptive Headlights 05AC High-beam assistant 0609 Navigation system Professional 0610 Head-up display 0612 BMW Assist 0614 Internet, preparations 0615 Expanded BMW Online Information 0616 BMW Online 0620 Voice control 0633 Preparation, mobile phone, Business 0654 DAB tuner 0677 HiFi System Professional DSP 0698 Area-Code 2 for DVD 06AA BMW TeleServices 06AB Control for Teleservices 06FL USB/Audio interface 06NF Music interface for Smartphone 06VC Control for Combox 0754 M Rear spoiler 0760 High gloss shadow line 0775 Headlining anthracite 0812 National version England / Ireland 0850 Dummy-SALAPA 0853 Language version English 0877 Delete cross-pattern operation 0880 On-board vehicle literature English 08KA Dummy-SALAPA 08S2 Coding alarm signal 08S3 Automatic locking when driving off 08SM Car ident. number visible from outside 08TF Active pedestrian protection 08TG Thiefproofing device 08TN Daytime run.lights adjus.via light menu 08V1 Label A105 105 AH AGM battery |
04-25-2019, 09:52 PM | #13 |
Rep 34
It doesn't really have any options. Not sure if that's important to you.
The only things I can see are comfort access and heads up display. I would definitely go for a car with Bang and Olufsen. I have every option on my car but the most important ones to me are heads up display, B&O, comfort access, and seat ventilation. I personally love having options, but some don't like to as they see it as just a more complex machine that has more things to go wrong, which isn't untrue. As for the mileage, most "common" issues are overblown, just like with any car. At the end of the day, a small percentage of owners are on the forums and other various groups. And even less people will purposely take time out of their day just to write a post saying "drove my car for 60k miles without any issues." My car is a 2013 with 61k miles, doesn't consume more than maybe half a liter of oil between oil changes, and has been dead reliable apart from a door lock actuator. Suit yourself, it's all about what you need or prefer. |
M5Rick60072.50 |
04-28-2019, 06:26 AM | #14 |
Rep 132
Hi,
Thanks again for all your replys, I have decided to pull the plug on that particular car, The dealer was difficult to deal with over the phone so i will move on. I'm just going to wait for exactly what i want, has to be Monte Carlo Blue with black leather and M seats. Defo 20" rims also. Not too bothered about options although they can be nice to have. Service history and the break in service will be my main priority. Cheers |
04-28-2019, 11:39 PM | #15 | |
Rep 294
200% what he said. Pre LCI's will tank harder in value and hold their lesser value in re-sale. Weaker Fuel pumps and the older version of injectors are known to bomb the engines. 2015+ have better clutches. |
Chiraq M528.00 |
06-20-2019, 07:21 AM | #16 |
Rep 132
Hi,
I have been looking for a couple of months now, a 2012 with 40k miles in the colour i have been looking for has popped up for sale, its service history is bang on with run in service etc complete. the option are listed below and it seems to tick all the boxes. thoughts on this spec please S754A M Rear spoiler Comfort and interior equipment S403A Glass roof electrical S415A Sunblind rear S416A Roller sun vizor rear lateral S428A Warning triangle and first aid kit S430A Interioroutside mirror with auto dip S431A Interior mirror with automaticdip S441A Smoker package S465A Throughloading system S488A Lumbar support driver and passenger S4MAA M multifunction seat S4NBA Autom climate control with 4zone ctrl S423A Floor mats velours S494A Seat heating driverpassenger S4URA Ambient interior lighting Multimedia S601A TV function S609A Navigation system Professional S610A Headup display S612A BMW Assist S614A Internet preparations S615A Expanded BMW Online Information S616A BMW Online S620A Voice control S633A Preparation mobile phone Business S654A DAB tuner S677A HiFi System Professional DSP S696A DVD changer S698A AreaCode 2 for DVD S6AAA BMW TeleServices S6ABA Control for Teleservices S6FHA Rear Professional entertainment center S6FLA USBAudio interface S6NFA Music interface for Smartphone S6NRA Apps S6VCA Control for Combox - Bavsound speaker upgrade available Driver assistance and lightning S508A Park Distance Control PDC S524A Adaptive Headlights S575A Supplementary 12V sockets S5ACA Highbeam assistant S5ADA Lane departure warning S5AGA Lanechange warning S5DLA Surround View S502A Headlight cleaning system S522A Xenon Light Wheels and drive S245A Steering wheel column adjustmentelectr S248A Steering wheel heater S2NZA BMW LA wheel M Double Spoke 343 S2PAA Wheel bolt retainer S2VBA Tire pressure display S223A Dynamic Damping Control S2MKA M doubleclutch transmiss wDrivelogic Environment and safety S316A automatic trunk lid mechanism S319A Integrated universal remote control S322A Comfort access S323A SoftCloseAutomatic doors S3AGA Reversing camera S850A ZUSAETZL TANKFUELLUNG EXPORT S877A Delete crosspattern operation S880A Onboard vehicle literature English S8KAA OELWARTUNGSINT 30000KM24MONATE S8S2A Coding alarm signal S8S3A Automatic locking when driving off S8SCA Telematics access requestcountryspec S8SMA Car ident number visible from outside S8TFA Active pedestrian protection S8TGA Thiefproofing device S8THA Road sign detection S8TNA Daytime runlights adjusvia light menu S8V1A Label S302A Alarm system S853A Language version English Individual equipment S761A Individual sunshade glazing S776A Headliner in Alcantara anthracite S760A High gloss shadow line Other equipment S1CAA Selection of COP relevant vehicles L812A National version England Ireland SXE7A Indi int strips piano lacquer black S1CCA Auto startstop function S1CDA Brake Energy Regeneration - Sign BMW individual - ZAP8 BMW Individual extended leather trim Graphite - Extended leather Merino graphite - nb 7 975 328 Sun Reflective Technology - Sewing thread graphite nb 2 272 113 code 0130 H - Quilting yarn graphite nb 2 272 112 code 0130 H - Quilting yarn for Ornamental seam - Quilting yarn graphite nb 8 027 107 code 0130 H - Seam of front and rear seats according to Mmultifunction seats - Remainder of spec as leather Merino black code LKSW - 0XE7 BMW Individual interior tim Piano finish black - Interior trim strips in piano finish black II |
06-21-2019, 02:28 PM | #19 | |
Rep 533
40k miles is not a lot for this model year. Have it inspected, drive it, stare at it. If you look back at it while walking away, then it's The One. But please take a close look at the condition of the brakes and tires. Tires will cost $350+ per corner mounted and balanced, and brakes could run you between $2k-$5k. And you'll want an aftermarket service contract (warranty) because M = money when it breaks. Good luck!
06-30-2019, 08:10 AM | #20 |
Rep 132
Hi,
Still looking, the 2nd car I pulled the plug on had 6 owners and to me a worry, it also looked like new discs very soon.bI am now going to look at a very late 2013 LCI with the Competition package, it has 52k miles and again the seats etc I was looking for. I will keep you updated. whilst searching I found this https://www.ebay.co.uk/itm/2013-BMW-...cAAOSwW9VdGInL Found the rear badge amusing!!! |
06-30-2019, 10:06 AM | #21 |
Rep 1,254
Service history for sure, as others have mentioned. Try to buy a car from an individual rather than a dealer, as you have a better chance of getting service history. Also, try to find cars w/ as few owners as possible. Cars w/ multiple owners usually don't get the maintenance investment they need, for obvious reasons. Lastly, if you want to save yourself some money in the long run, look for a "turn-key" car, i.e. a car that doesn't need anything in the near future. Brakes, tires, interval maintenance, etc. Those things can easily add up to $2k (USD) each. I just replaced tires on my car after buying it in May to the tune of $1700. Oil change is up next, which I'll be doing myself.
Good luck and don't settle!
07-07-2019, 12:21 PM | #22 |
Rep 132
Hi,
I have put a holding deposit down on a late 2013 LCI with Comp package. I have not seen it yet and will go down in a few days. I have had a BMW report carried out and all checks out good, running in service etc all perfect. Tyres all at 6mm, and most importantly the brakes were fully replaced around 12k miles ago. Has also had a gearbox service and rear diff in late 2017. Plugs done around 20k ago. I have been told it is immaculate but will see for myself soon. it certainly ticks all the boxes. noticed it had a few top up oil visits but they were spread out around 9k km and these were in its earlier life. its a 2 owner car also. My only slight concern is the comp pack suspension, I have probably been reading into it too much but lots of conflicting comments regarding ride quality. will be strange for me moving from my big spongy CL500, however I have had some bone shaking cars recently and was not too bad, my 996 911!!!!!!! i'm 45 on Monday but feel like a kid on Christmas eve!! Anyway ill keep you updated, wish me luck!! [IMG][/IMG] |
94jedi830.00 |
