      09-10-2020, 09:31 AM   #1
M6ORL
M6ORL's Avatar
Drives: Bmw m6 bmw 530i
misfire cyl 6
hey guys I was driving on a bumper to bumper traffic the other day and I started to feel the car a little weird , as soon as I get off traffic I push the car a little bit and the drivetrain malfunction code turns on.
after scanning the car with a obd2 reader found out a cyl 6 misfire I shut the car off reset the code and it went away , I drove the car about 300 after that with no issues but I'm still concerning what could have cause that?? what is should check i plug the obd2 reader and no code was found ???? any ideas
I'm sitting on 75k miles
      09-10-2020, 10:37 AM   #2
vafan13
Drives: Sakhir Orange F10 M5
Coil going bad? Coincidentally, that's the same cylinder I had a misfire and DTMAL on, though mine didn't go away when I restarted. I replaced the coil and all has been good. Luckily it's in front of the ECU, so pretty easy to replace if you want to try that.
      09-11-2020, 05:41 AM   #3
technician117
1990 BMW M5  [0.00]
2000 BMW M5  [0.00]
2013 BMW M5  [0.00]
The best any of us can do is give you wild guesses. A random misfire could be just a glitch/hiccup or could be a lot of other minor problems.
I'd suggest removing the coil and spark plug to inspect it. Probably just change both since they will be out and are cheap.
