09-13-2017, 02:33 AM | #1 |
Rep 38
6WB coding tread
Hi,
because some of us installed already the 6WB Kombi i would like to start this tread. Here you can share your experience and findings with us. Some of you asked me for the compass function. This can be found in section 3003 FZG Ausstattung -> Kompass Graph Enable -> set to aktiv. I found also Motorleistung Enable which should show the engine power used (only workingin sportmodus). Unfortunately it is not working in my car. Maybe someone can try it and confirm. As it seems it is working at least for the F10 series cars. In my 2013 F31 is still the HUD not working, i guess a coding mistake (resolution, wrapping...?), so if someone can help me would be nice. |
09-16-2017, 03:22 PM | #4 |
Rep 38
Hi! Sorry if I hijack, Im trying to do the 6wb retrofit but so far I have no luck!
I have try everything I could imagine and everything I have read but no luck, I can't see Dkombi , only Bkombi... I have read and delete Bkombi from svt, I have swap fibre on connectors, I have try diferents esys.... Any ideas? |
09-16-2017, 05:26 PM | #5 |
Rep 82
I can do it for you via teamviewer now at the moment
hanh8thuan0.00 |
09-21-2017, 03:20 PM | #7 |
Rep 38
Hi all!
I have retrofitrd 6wb to my 2012 F30 and it seem to work everithing apart from that on kombi dosent show sport+ mode, it does on NBT.... this dosnt botther me much but one thing i cant solve is that the time and date dosnt save. I put it and it dosent get fix. I have try to change dates on FA, i have try codding diferents CAFD to nbt and kombi with no luck! Any ideas? Anyone has experienced this? Thanks. |
10-13-2017, 08:39 AM | #8 |
Rep 7
Hi All,
Just installed the 6WB on my 2016 F30. Everything is fine except the navigational display that I used to get on my 6WA does not show up? Anyone can advise what additional coding needs to be done up? Help appreciated thanks!! |
10-13-2017, 06:51 PM | #10 | |
Rep 7
and which module section is "HU_NBT kombi" ? Sorry for being such a noob. |
12-08-2017, 04:10 AM | #11 |
Rep 38
Did someone found a solution for the HUD issue? Mine is still not working. Sometimes it is starting up but after a couple of seconds it turns off again.
Another problem with the 6WB is that the navi advise does not disappear. It stays until the next advise. Have anyone the same behavior? THX |
12-09-2017, 05:22 AM | #12 |
Rep 80
From what i understand the steps for coding after replacing in fa 6wa with 6wb are :
a)inject cafd for dkombi b)vo code dkombi c)vo code nbt but how to tell wich cafd to use ? i selected the one wich is same with my i step but i still have trouble setting the date. |
12-13-2017, 10:59 AM | #15 |
Rep 41,181
Drives: 2018 Alpina B6 650ix GC
FDL Code HU_NBT => KOMBI_CIC = kombi_high.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
01-22-2018, 08:53 PM | #18 |
Rep 742
Changing "Motorleistung Enable" to aktiv didn't enable the hp/tq on the cluster.
I did find 3000->BMW logo -> default:BMW, changed to MPM. Waiting 10 mins for the car to sleep to test this out. EDIT: changing the bmw logo to MPM shows "m550i(or m550d, cant remember". Other options are bmw_i, bmw_x5, bmw_x6, unk_param_0, unk_param_1, unk_param_2, and unk_param_3. Is there a way to increase the splash screen time?
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) Last edited by jkwhar; 01-22-2018 at 09:59 PM.. |
02-26-2018, 11:43 PM | #20 | |
Rep 407
02-27-2018, 02:13 AM | #22 |
Rep 12
Hi at all, anyone know the mimun istep for 6wb installing? my car as 16 7 506.
Thanks Max |
polinesiano1.50 |
