03-01-2014, 06:16 AM | #1 |
Rep 67
DCT Judder
Hi Guys,
As above on a couple of occasions if I reverse when the car is cold up a sloped driveway (not very steep, just slight incline), the clutch seems to judder slightly on take-up . Anyone else noticed this or is it a trip to the dealer? Not sure if its temperature related, I haven't had the car long and its only done it when its been about 4 degrees C outside. The car is an early 2013, so probably built late 2012, 20k miles on the clock. Any advice appreciated. |
03-01-2014, 06:39 AM | #3 |
Rep 67
03-01-2014, 12:04 PM | #5 |
Rep 1,155
Yes - you have to drive it as if it were a conventional manual - you can wind up juddering on occasion - even in second.
2009 Aston Martin DBS - Casino Royale Gray on Black (sold) 2014 M5 ZCP - Azurite Black over SSII Full (gone) 2009 M5 - Carbon Black over Sepang Full (gone - not forgotten) 2001 740i M-Sport - Carbon Black over Black (gone - not forgotten) |
03-01-2014, 12:13 PM | #6 |
Rep 785
My DCT has juddered on one occasion in D whilst driving through heavy traffic when I wasn't particularly gentle with the throttle pedal. Other than that it's always been very smooth. Far better than our DSG equipped car which can almost stall when under load during cold start/low speed manoeuvring.
03-01-2014, 02:51 PM | #8 |
Rep 1,622
When cold starting the car, it's a good idea to stay still until the RPM's drop down to normal idle (takes between 10-20 seconds). Then once it's at normal idle you can put it in D/R gear and move.
03-02-2014, 01:45 AM | #9 |
Rep 3,450
What does judder mean here,
i have problem when the car is incline (forward) and something's like holding the drive shaft and diff,
03-02-2014, 07:25 AM | #10 |
Rep 67
Judder; meaning shudder or vibration through the transmission. These cars have hill start assist, the car holds the brakes for a few seconds on inclines after you release brake peddle, its designed to stop you rolling backwards during the transition from brake to accelerator - Perhaps this is what you are describing.
03-02-2014, 09:52 AM | #11 | |
Rep 3,450
the other day the dealer said it was normal since the motoric is braking, however i climb the incline directly without braking and at times these vibrations kept vibrating and making noise…. (comes from around the middle rear part of the car…) - confusion, the car was scanned and no fault appeared.. so what should i do guys?
03-02-2014, 12:14 PM | #12 | |
Rep 67
03-02-2014, 12:53 PM | #13 | |
Rep 571
03-02-2014, 06:08 PM | #15 |
Rep 225
Reversing the car on an incline is one of the worse things you can do to your dtc clutch.
The juddering you're feeling is the clutch engaging and disengaging. You're putting a lot of extra wear on whichever clutch controls reversing. |
03-02-2014, 06:15 PM | #16 |
Rep 3,450
Okay then, i guess i don't have to bring my car in to the dealership ?
03-03-2014, 08:23 AM | #17 |
Rep 195
Mine does the same, I guess is not temperature related, is more like torque delivery, in 2nd gear slow incline, if rpm below 2000, dct tends to down shift to 1st but at the same time, the car efficient programming try to stay in higher gear, that's why the clutch engage and disengage.
I change the shift speed to level two and the problem goes away, but then again, its annoying to change it everytime you start the car |
03-03-2014, 08:43 AM | #18 |
Rep 739
So how do you suggest we back up an incline?
03-03-2014, 10:24 AM | #19 |
Rep 67
I'm a bit puzzled as to how reversing up an incline is any more harmful to a DCT than driving forwards up an incline - please explain?
03-03-2014, 10:39 AM | #20 | |
Rep 225
Ill first say I don't have an m5 yet. I do have a ton of experience with my old e46 smg m3's. Same concept though. It's especially worse if you're reversing slowly up an incline which most rational drivers do : ) If you can find a way to go up the incline facing forward you're better off. |
03-03-2014, 10:41 AM | #21 | |
Rep 225
