      06-17-2013, 10:43 PM   #1
PatrickC23
PatrickC23's Avatar
2013 BMW ///M5  [0.00]
Squeak after engine/ignition shut off
Do any of you guys get a squeak from underneath the car after you turn the ignition off? It happens to me every time, at first I thought it was the suspension lifting as I got out of the car, but now as I open the door and havent gotten out yet I hear it. Its a single short squeak that almost sounds like the exhaust valve closing, but I dont always drive in Sport+ so not sure if its even open all the time.
Thoughts?
2016 991.1 911 Carrera GTS
      06-17-2013, 11:29 PM   #2
alexey21
Drives: Turbo
it might be the valve. I found it to be open even on comfort while i was on ED. Shortly after shutting down car I found it to be closed again.
      06-17-2013, 11:36 PM   #3
mwlmd
mwlmd's Avatar
Drives: Porsche 991 TTS
yes. no clue why.
CURRENT:
His: Porsche 991 Turbo S
Carrera white/Black
Hers: BMW X3MC
BSM/Black
      06-18-2013, 11:21 AM   #4
chudak18
chudak18's Avatar
Drives: E92 335, W463 G55
I've always coincided that with the secondary parking brake.
      06-18-2013, 11:30 AM   #5
PatrickC23
PatrickC23's Avatar
Guess ill have my wife shut off the engine while I try to watch the valve - i also thought maybe parking brake. Theres a secondary brake?
      06-18-2013, 11:40 AM   #6
bobblehead
bobblehead's Avatar
Drives: warp speed
I thought it was the engine pulley coming to a stop
      06-18-2013, 12:16 PM   #7
chudak18
chudak18's Avatar
When you shut the ignition off (second push) another brake, more of a parking lock, engages. even if you leave the car in neutral and shut the ignition completely off, Not engage the hand brake, then try to push the car it won't go anywhere because of the secondary parking brake. That is the squeak that you're hearing. Are there people that don't have this sound? I thought it was normal. Wtf...
      06-18-2013, 12:35 PM   #8
PatrickC23
PatrickC23's Avatar
Thats good enough for me - I actually noticed it a while ago but didnt mention it at my 1200 mile service, because I couldn't bear to let my car be away from me longer than for just the break in service.
All kidding aside, when it first started and I thought it was the suspension lifting as I got out, I started a diet.
      06-18-2013, 12:37 PM   #9
Drives: Black M5
I've never heard the secondary parking brake squeeking on and off before. Then again I don't hear a lot of stuff because of the straightpipes.
      06-18-2013, 12:44 PM   #10
PatrickC23
PatrickC23's Avatar
U are probably legally deaf
      07-15-2014, 07:08 AM   #11
zirotti
Drives: lots
Old thread I know, but I've noticed this a handful of times now. Even my wife asked what it was last night.
Is this something that people are having addressed at the dealer?
      07-15-2014, 07:16 AM   #12
ghueser
Drives: 2014 M5
It's not that. There is definately a short "squeal" noise coming from the engine compartment around 10 seconds after shutting off the engine. Shutting the car down and putting it into park makes a clunk, the parking brake also makes a distinctive sound. This is something different. I'm wondering it this is the turbo boost relief valve (do we even have them?) My theory would be that once the engine shuts down, the ecu relieves pressure still present in the manifold. ????
      07-15-2014, 09:27 AM   #13
Spinny02
Spinny02's Avatar
It's the valve on the mufflers
      07-15-2014, 09:34 AM   #14
JOHNBMWM5
JOHNBMWM5's Avatar
Every time I shut down, the Fans and Oil pump for the turbos runs for some 5 minutes. Thats it. But I have the Valves wired open
      07-15-2014, 10:46 AM   #15
TonySCV
Drives: '18 M2; '21 X6 M50i
Common problem.
Discussed here: http://f10.m5post.com/forums/showthread.php?t=996858
And here: http://f10.m5post.com/forums/showthread.php?t=967582
      07-15-2014, 10:55 AM   #16
zirotti
Drives: lots
Thanks Tony. But definately not side bolsters or coming from the inside of the car. Sounds like coming from near rear axle on bottom of vehicle.
      07-15-2014, 10:58 AM   #17
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
It's E-Brake
      07-15-2014, 01:10 PM   #18
ghueser
Drives: 2014 M5
It's not the E-Brake making this noise, or the side bolsters, or the cooling system afterrun for the turbo's, or the door locks, or the parking pall for the transmission................etc. (These all make seperate distinctive sounds.)
Before shutting down your engine, roll your window down. The sound takes place roughly 3 seconds after shutdown and is a quick squeal. Reminds of sound that something would make that needs lubricating. It is definately coming from outside the car...either underneath the car..maybe the valves in the exhaust, or from the engine bay somewhere. Im going to look at the exhast valves tonight, otherwise think it could be the actuators on the turbos.
      07-15-2014, 01:14 PM   #19
mpower3330
Drives: F90 M5 Comp
I bet it's the valve on the mufflers. Mine used to make this noise but has stopped since I wired the valves open.
      07-15-2014, 01:47 PM   #20
Fantasm
Algeria
39
Drives: SL63
I bet if you got a Toyota it wouldn't make any more noises.
BEFORE: 24+ Other Awesome Cars - BYE - My Straight Piped Ferrari 458 (plus other mods): http://goo.gl/2qf5fW
      07-15-2014, 02:10 PM   #21
M5essex
M5essex's Avatar
England
642
Drives: RR sport SVR, Vent S, 650s spi
Defo the muffler valves. Mine does it every time I get out after turning ignition off.
Current - 2016 McLaren 650s Spider, Aurora Blue
Current - 2016 Range Rover Sport SVR- Black
Current- 2018 Aventador S. Nereid blue
Gone - 2016 F80 CP, 2015 991 Turbo S, 2016 LCI M135i. 2015 F10 CP M5. 2015 X5, 2012 E92 CP M3. 2009 E92 335i
      07-15-2014, 02:41 PM   #22
ghueser
Drives: 2014 M5
I might spray a little WD-40 on the hinge points of those valves once the exhaust cools down. Might not last long but will see what it does.
That is one thing I have definately noticed with this car.....OMG that exhaust gets hot! You can feel the waves of heat getting out of the car.
