      08-01-2023, 05:35 AM   #1
D4T
Drives: 2013 F10 M5 LCI
smooth running test - worth running just because I can?
Hi all,
So I don't have any issues with the car currently (fingers crossed) but I have seen of engines lock because of leaky injectors and this makes me nervous now my car is 10 years old with 70k miles on the clock.
Is there any harm or benefit in running ISTA's smooth running test? Is it likely to actually do anything given I dont have any codes or anything?
I know some of you replace injectors as a preventative measure but others seem to think its pointless doing so as injectors can fail at random in their lifetime.
Can anyone help or offer some advice to put my mind at ease?
Thanks all!
      08-02-2023, 09:51 AM   #2
SpeedProtocol
SpeedProtocol's Avatar
Drives: '14 F10 M5 - '21 F90 M5
You can run it if you want to. There is a step that should pressurize the injectors and see if it holds. Its a good way to tell if they are starting to leak or not.
I cant remember if its called smooth running or misfire detection.
-=SpeedProtocol=-
2014 M5 Sakhir Orange- BPM Stage 1 - Soul Performance Exhaust - PG Intakes - CarboTech 1521 Pads - Turner Monoballs
2021 M5 Motegi Red- Stock
      08-02-2023, 09:53 AM   #3
D4T
So basically no harm done if i do? Just wondered if its actually good at finding any faults or not.
      08-02-2023, 10:16 AM   #4
TinCanSailor
Fueled by Recycled Dinosaurs!
TinCanSailor's Avatar
630
Drives: F06 M6
There is a youtuber that I think participates on these forums kern417 that did a video on checking injectors to see if they are stuck open. Although most of the videos are based on the B58 many of the topics are general enough to educate us all.
D4T10.50
M5Rick60091.50
      08-03-2023, 06:53 AM   #5
D4T
Great video and really good idea on how to check, thanks a lot for that will give it a go
      08-03-2023, 08:18 AM   #6
TinCanSailor
630
Drives: F06 M6
Although I do not have a B58 or S58 I watch a lot of the videos he posts up as he runs a great data-centric channel.
Please keep us posted on how things go.
      08-04-2023, 02:13 PM   #7
SpeedProtocol
I mean the computer literally pressurizes the system and sees if the pressure drops or not. I would think that would be pretty good at finding faults. It shows the psi and each injector on the screen.
-=SpeedProtocol=-
