06-16-2016, 09:50 AM | #1 |
Rep 1,202
Cold Start Idle Oscillation
Figured I'd ask the following question, as its become more frequent over the past few weeks:
Upon cold start, if I throw the car into reverse and try to drive with the car still in cold start warm-up (elevated RPM), the RPM oscillates noticeably when slowing to a halt (which has caused the car to stall in once instance). Though, if I let the car warm up for 30 seconds so that it finishes the cold-start cycle and brings the RPM down to normal, and then start driving, the car runs perfectly normal without any issues. From experience with my N54 335, fuel system-related issues (plugs, coils, injectors, etc.) tend to cause RPM oscillation after the cold-start cycle finishes and the car is at operating RPM. Car does not throw any codes and otherwise runs perfect in all other situations. Overall, I can avoid the issue altogether by allowing the car to warm up properly and finish the *** warm up cycle, or can replicate it by attempting to back out of my garage mid-warm up. |
06-16-2016, 10:58 AM | #2 |
Perennial PFC
336
Rep 1,274
If your M5 has the DCT perhaps it is a clutch release situation? Maybe line pressures aren't fully up and it doesn't release properly when you brake to a stop? Just a guess of course, I haven't had this problem.
06-16-2016, 11:16 AM | #3 |
Rep 1,805
Drives: 2014 BMW M5 F10 CP
Check coil packs
06-16-2016, 01:03 PM | #4 |
Rep 1,202
Yes, car is DCT.
I know the E9X had idle control valve issues that exhibited similar symptoms, but I've never heard of any M5's with the issue. Anytime I've had plug/coil/injector issues on my E92 M3 and N54 335 the car has thrown codes (usually misfire) and/or had a rough idle after the car completes its cold-start cycle (both of which do not occur in this case). If I'm patient and give the car 20 seconds I will never experience this issue, just wanted to see if others have came across it as well. |
06-20-2016, 09:55 PM | #5 |
Rep 1,840
I notice it when the wheel is almost hard over when parked.
06-21-2016, 10:15 AM | #8 |
Rep 1,202
