      06-22-2016, 02:23 PM   #1
Pro-AM3
Drives: E90 M3
F10 1/4 and 1/2 Mile MPH's
Does anyone know what the current standings are of the F10 1/4 and 1/2 mile records?
      06-22-2016, 03:46 PM   #2
allmotor_2000
1087
Drives: 2018 RS3, 991 Turbo
Since I have the record for both...
9.9 ET and 142.5mph in the 1/4
175.5mph in the 1/2
      06-22-2016, 04:05 PM   #3
Msizzle
Drives: 2013 M6 Coupe
allotter out of all these big power m5's you are the only one with some 1/4 times every step of the way. My setup is mild compared to you but I'm def going after a 10sec slip in the next week or two
      06-22-2016, 04:42 PM   #4
TheHouseWon
TheHouseWon's Avatar
644
Drives: 2013 M5
What's your set up?
      06-22-2016, 06:01 PM   #5
allmotor_2000
1087
doable!!
      06-24-2016, 02:50 AM   #6
Drm5
Puerto Rico
30
Drives: F10 M5 sakhir orange
170mph in the 1/2
did u have turbo upgrade for the 1/2 mile time?
      06-24-2016, 06:00 AM   #7
onfireX5
Drives: F90M5,F85X5M
170 in the 1/2 is getting it done !
      06-24-2016, 12:10 PM   #8
allmotor_2000
1087
Yeah stage 1's, but car actually wasn't running well as I had blew my ice-tank pump (didn't know) and IAT's were like 50 degrees higher.
I think 175 is doable.
      04-30-2017, 10:30 AM   #9
cjrdriven
Drives: 2014 BMW M5
Do we know what stock Turbo record is for the M5? 🤔😉
      04-30-2017, 10:48 AM   #10
TheHouseWon
644
Drives: 2013 M5
And stock springs and headlights if any has the numbers
      05-01-2017, 10:57 AM   #11
allmotor_2000
1087
Originally Posted by cjrdriven View Post
Do we know what stock Turbo record is for the M5? ����
M6 is like a 10.4 or something. M5... I am sure it can be close to that, but I think its is in the 11's...
ARC550446.00
      05-01-2017, 11:42 AM   #12
ARC550
Stock turbo M6 record I have at 10.3 at 135mph with a hugest trap of 139 on the 1/4.
As for M5 stock turbo record I think it's 10.9 or something.
I did 11.5 stock
11.2 wig just map 1 on bms(JB4)
Doing FBO next 2 weeks and will let you know how that goes.
But yea Allmotor is king of speed for the Ms
      05-03-2017, 07:47 PM   #13
Msizzle
I did 11.5 stock
What was your setup for that??
      05-03-2017, 10:42 PM   #14
ARC550
I did 11.5 stock
10.3 setup?
Backend flash, JB4 (28psi) , Downpipe and Intake
And to hold the power I had clutch, and axles.
      05-04-2017, 12:27 PM   #15
allmotor_2000
1087
10.3 setup?
No meth?
      05-04-2017, 10:28 PM   #16
ARC550
10.3 setup?
No meth?
Nope lol just boostane octane booster and a splash of E85 lol and of course JB4 at 28psi
      05-08-2017, 05:27 PM   #17
Msizzle
10.3 setup?
I will pretty much have the same but no down pipes, can't wait!
      05-08-2017, 08:16 PM   #18
evilb
evilb's Avatar
I did 11.5 stock
10.3 setup?
Any weight reduction?
      05-08-2017, 11:14 PM   #19
ARC550
10.3 setup?
You need Downpipes. That is Big key!!
      05-08-2017, 11:15 PM   #20
ARC550
I did 11.5 stock
10.3 setup?
None at alll!!! Alll untouched.
      05-12-2017, 11:26 PM   #21
cjrdriven
Drives: 2014 BMW M5
Hit 161 in 1/2 stock Turbos on 24psi. Wish I could have hit 28psi as I bet I had a record on stock Turbos easy!
      05-20-2018, 03:58 PM   #22
epiphanyray
Drives: 2003 E39 M5 + 2013 F10 M5
10.3 setup?
I have a similar setup except the axles. I was curious, do you have any 60-130 results/logs? Would you be so kind as to share your settings on JB4 Map 6? I want to compare with what I have.
I just did a 7.05 60-130, but hoping to get into 6.8 territory with Mickey Thompsons.
Thanks!
