      10-08-2023, 03:58 AM   #1
mpower112
Drives: G20
Hybrid Turbos Power Loss
Hi ,
I just pick up my car after a stage 2 hybrid turbo upgrade and the car have no power from the bottom , nothing really happen until 4k rpm then the car start to have some power
The garage making the upgrade tell me that because i put the hybrid turbos i need proper tune for them and then i gonna have the power at the bottom as well
Currently driving on BM3 Stage 2 tune
Anyone experienced same issue after turbo upgrade , is this normal?
Also throw code
104302 "Pressure to low after run"
101FO2 "Air Mass system plausibility"
M5 F10
Forged Engine
Deka Clutch Stage 2
Upgraded InterCooler
DP
CP
Intake
BM3 Stage 2 Tune
M5Rick60090.50
      10-08-2023, 09:59 AM   #2
Amitt
Amitt's Avatar
Drives: F10 M5 | E92 335i
2015 BMW M5  [0.00]
2009 BMW 335i  [0.00]
BM3 OTS maps are for stock turbos. You need a custom tune for your setup.
M5Rick60090.50
      10-08-2023, 12:11 PM   #3
M5_Brandoe
M5_Brandoe's Avatar
Drives: Black sapphire M5
+1 def need a custom tune for that setup.
Instagram MRBrandoe
M5Rick60090.50
      10-08-2023, 04:35 PM   #4
Blaxwil
Blaxwil's Avatar
627
Drives: 2015 M5
A custom tune is mandatory with that set up. You’ll need more boost on the lower gears for those turbos to even start spinning good.
It sounds like you have everything planned out so the question is how did your shop drop the ball on a custom tune? Respectfully. Nice set up though. Did you also upgrade your driveshaft, rods,
Pistons and bearings?
      10-08-2023, 08:51 PM   #5
M5_Raz
M5_Raz's Avatar
514
Drives: BMW M5
Ditto on what everyone said. Don’t drive it anymore without a custom tune. You could ruin the engine and turbos.
      10-09-2023, 05:37 AM   #6
What actual 'custom' tune you need will be determined by a tune expert over there, just have to look for one that is knowledgable with this.
      10-10-2023, 07:46 PM   #7
mpower112
Drives: G20
Thanks for the reply
Stock driveshaft , upgraded rods , bearings and JE Pistons
My shop tell me that i need new tune but he can't do it because he is not a tuner
So the code thrown is most likely related to upgraded turbos and no tune ?
What power can i expect from that setup ?
      10-10-2023, 08:13 PM   #8
Blaxwil
Blaxwil's Avatar
627
Drives: 2015 M5
Here’s an example, I’m running a mild BPM stage 2 tune, MSR intakes and Fabworx catless downpipes. I’m sitting on roughly 705 HP with 675 TQ.
All this was well calculated and mapped out. I’ve been running this same set up for about 90k miles. I could have easily gotten another 40-60 more HP and TQ out of it but at what cost?
As I said in my previous post, you’ve spent the bread to have a well built machine. Trying to squeeze all the juice out will ultimately put you into the same boat as many others who’ve tried to push this platform to the very limits.
If I were you (and I am you), I would keep your HP below 750 and the TQ below 700. Find a happy spot for those hybrid turbos and enjoy the hell of it (occasionally). I also wouldn’t spend a lot of time punching it from a dig.
M5Rick60090.50
      10-10-2023, 08:15 PM   #9
Blaxwil
Blaxwil's Avatar
627
Drives: 2015 M5
What year is the car?
      10-21-2023, 05:16 PM   #10
mpower112
Drives: G20
2013 120k km
I was on 730HP 900NM before turbo upgrade but i want little more power , will go for tune next week and gonna see but around 800HP should be good and safe
Thanks for all advice
      10-21-2023, 05:24 PM   #11
Blaxwil
Blaxwil's Avatar
627
Drives: 2015 M5
What color is it? Send some pics.
