      08-03-2014, 09:21 PM   #1
soooma
///MD
soooma's Avatar
Drives: M5 F90
Wider tires 305 25 20 on stock 343 rears?
Any experience ?
Is it doable?
Any risks?
Is it worth it?
Speedo error?
Or should be
305 30 20?
Life is too short even if you live to be a 100!!
As what really counts is the few moments we are really happy and excited!
-Kids, Family, Success, Career, Helping others stand on their feet (Paying back and sometimes forward), Travel, Seeking the truth, Reading, Hobbies eg ///Madness -
      08-03-2014, 09:41 PM   #2
Fantasm
Algeria
39
Drives: SL63
305/30/20 works perfectly fine. im running nitto nt05's in that size right now. i have a whole lot better traction but thats due to the tire change too, not just the width increase.
BEFORE: 24+ Other Awesome Cars - BYE - My Straight Piped Ferrari 458 (plus other mods): http://goo.gl/2qf5fW
      08-03-2014, 09:56 PM   #3
M5TXGuy
M5TXGuy's Avatar
Drives: 2013 M5 BlackSapphireMetallic
Im about ready for new rear tires and was thinking of going to 305s as well. If I make the switch, would I need to take the 10mm spacers out?
      08-03-2014, 10:14 PM   #4
Fantasm
Algeria
39
Drives: SL63
Nothing needed -- no rubbing at all even during power slides and very aggressive cornering.
I believe the NT05's I'm running are even a bit thicker than the Michelin PSS too, and I'm running them at 38psi cold (which is more than stock PSI).
      08-03-2014, 10:19 PM   #5
Fantasm
Algeria
39
Drives: SL63
Sorry, I read your question wrong, I thought you asked if you would need to add 10mm spacer.
I don't think you would need to remove it, but I am not totally sure - looks like it will be fine though.
Either way, if you do have to remove it, it doesn't sound like a bad thing since you are getting the natural width extension from the tire without the spacer being required.
      08-04-2014, 06:09 AM   #6
PatrickC23
PatrickC23's Avatar
2013 BMW ///M5  [0.00]
Can you run 305 rears with either 265 or 275 fronts? Is either preferred since my fronts probably will jot need replacing at the same time.
      08-04-2014, 07:12 AM   #7
JOHNBMWM5
JOHNBMWM5's Avatar
I would not "Mix axles" tyre wise, but it's up to you, check for "insurance issues" should an accident occur.
      08-04-2014, 11:02 AM   #8
Fantasm
Algeria
39
Drives: SL63
What do you mean by mix axles? I don't think he meant he wants to run 265 on left and 275 on right. He said either or.
      08-04-2014, 11:40 AM   #9
JOHNBMWM5
JOHNBMWM5's Avatar
I mean one type of front tyre and another type on the rear axle.
Is he buying all 4 tyres or just two?.
      08-04-2014, 11:59 AM   #10
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
Originally Posted by soooma View Post
Any experience ?
Is it doable?
Any risks?
Is it worth it?
Speedo error?
Or should be
305 30 20?
The total diameter for 295/30/20 is 26.968"
The total diameter for 305/25/20 is 26.003"
so you will expect about 3.5% speedo error means when your speedo shows 100 mph, your actual speed is 96.5 mph if there is no other built-in speedo error which there is (your speedo always shows a bit more than actual speed)
The total diameter for 305/30/20 is 27.204"
In this case your speedo has less than 1% error and shows 1% less than actual speed,
If I were you, I would go with 305/30/20 and I don't see any issue since I have seen M5 with 433M wheel which is 1/2" wider than M5 343M
      08-05-2014, 11:12 AM   #11
PatrickC23
PatrickC23's Avatar
I meant when my rears go - Id get 305 in the rear with my oem fronts, but Id get PSS all around. Didnt know if 265f and 305r would cause any difference.
2016 991.1 911 Carrera GTS
      08-05-2014, 11:38 AM   #12
mcvaughan
mcvaughan's Avatar
Drives: F87 Competition
More under steer.
Matt
      08-05-2014, 03:13 PM   #13
Knight Commander
Originally Posted by mcvaughan View Post
More under steer.
Exactly which is why you want to increase size of both front and rear. I would do 305 rears and 275 fronts, and use same wall as OEM tires. PSS is available in that configuration.
2022 Mercedes-Benz EQS 580
2020 Mercedes-Benz GLE 450
      08-05-2014, 03:44 PM   #14
HXS
Licensed Drug Dealer
HXS's Avatar
Unfortunately, minimum recommended wheel width for 305's is 10.5.
      08-05-2014, 04:16 PM   #15
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
I'm not sure if this is correct ???? I found some links 10" should be fine!
http://mostwheels.com/rimwidth.html
      08-06-2014, 01:55 AM   #16
HXS
HXS's Avatar
Click here, then click "Specs".
Rim width range: 10.5-11.5
