      02-10-2017, 08:38 PM   #1
AutoTalent
AutoTalent's Avatar
2307
Drives: e92 M3 6mt | e60 M5 6mt
Dinan Tuner | Exhaust | Intake | Suspension F10 M5
Golan@AutoTalent.com
DINANTRONICS Performance Tuner Stage 1 and 2 for BMW F10 M5
The DINANTRONICS™ Performance Tuner is a highly engineered and sophisticated piece of computer hardware and software that enhances engine performance, without negating or voiding your new car warranty coverage and without affecting long term reliability or the functionality of on-board diagnostic systems. It is also the only tuning device emissions legal in all 50 states. The ultimate objective of developing this piece of technology was to provide the ability to control every signal entering and exiting the BMW factory Engine Control Unit. These items are unique to Dinan and together they embody the apex of performance engineering in a powerful, reliable, and warrantied package.
Dinan Free Flow Stainless Exhaust for BMW F10 M5
Dinan’s Free Flow exhaust system features 100% stainless steel construction measured to exact specifications to ensure proper fit via factory hangers and mounting points. Dyno tuned for maximum exhaust flow with minimum backpressure, this system is designed to provide a more aggressive sound under acceleration, while reducing drone inside the vehicle, thanks to Dinan’s exclusive Helmholtz Chamber and Butterfly Valve technologies. The exhaust gasses exit through larger laser engraved ultra durable satin black ceramic coated quad tips.
Every Dinan product comes with our industry exclusive factory matching new car bumper to bumper warranty and is designed and tested in Morgan Hill, California and can be purchased and installed at any Dinan Approved BMW dealership nationwide.
Benefits of the Free Flow Exhaust
+ Improve performance by 8 horsepower
+ Throaty, deeper sound
+ 100% 304 Stainless Steel Construction
+ Helmholtz chamber to remove drone
+ Incorporated Butterfly Valve technology
+ Simple installation using high quality BMW clamps and hangers
+ Quad 3.5" laser engraved black ceramic coated exhaust tips with Dinan logo
+ "Straight through" canister design
*AVAILABLE IN BLACK AND CHROME TIPS
Dinan Carbon Fiber Cold Air Intake for BMW F10 M5
The F10 M5 Dinan high flow carbon fiber cold air intake, like most Dinan products, has a sleek and functional appearance that embodies high performance. The F10 M5 cold air intake allows cool outside air to be pushed into the engine via a pair of supplemental carbon fiber intake ducts located at the front of the engine bay. The M5 cold air intake system was carefully designed within tight packaging constraints and in consideration of ideal aerodynamic diffusing angles to optimize the efficiency and performance of this induction system. Each duct leads combustion air through a custom designed intake assembly that has a larger than stock metered air flow housing, as well as a Dinan conical air filter with a 77% larger capacity. Dinan engineers have painstakingly developed custom tooling to ensure the entire Dinan cold air intake system is sealed like a factory replacement, thereby preventing hot air from the engine compartment to compromise its effectiveness. The stock air inlets are left intact and fully functional to provide a new total of four air intakes into the engine for maximum airflow. Improved induction airflow offered by Dinan cold air intake systems increase engine performance, even more so if used in combination with other performance enhancing Dinan products.
The F10 M5 Cold Air intake is in compliance with U.S. EPA Memorandum 1A, or this product has not been found, nor is believed to be, unlawful for use under the provisions of the Clean Air Act. Currently: This product is not legal for sale or use in California, or states that have adopted California emissions standards, on any pollution controlled motor vehicles.
Benefits of Dinans Cold Air Intake:
+ Maximum peak power of 693 HP and 651 lb-ft of Torque utilizing Dinan Stage 2 components (DINANTRONICS Performance Tuner, intake and exhaust). A difference of 13 HP and 7 lb-ft of torque from Dinan Stage 1 (D-TRONICS Performance Tuner Only).
+ Dinan proprietary Injection molded Dinan MAF housings are larger than stock
+ Stock air filters are replaced with 77% larger Dinan conical air filters.
+ Entire Dinan Intake system is sealed like a factory replacement to ensure only cold outside air and not hot air from the engine compartment is being utilized.
+ Stock System Stays Completely Functional
+ Carbon fiber air box lids and intake ducts
+ Raised Dinan logos are laminated into the carbon fiber intake
+ Rubber hoses, mounting brackets, & hardware included.
Dinan High Performance Adjustable Coil-Over Suspension System for BMW F10 M5
For the driver that demands the best out of their vehicle. The Dinan Adjustable Coil-Over Suspension was bred in the race lab but refined on the street for maximum versatility. No matter the environment, the traction that is bestowed upon the vehicle from the improved suspension will inspire new found confidence when running at higher speeds. Combined with a substantial reduction in body roll as well as reducing dive under breaking and squat under acceleration. Dinan will guarantee you superior handling, performance, and comfort. Dinans design keeps the factory Electronic Damper Control shocks in place and implements threaded collars to allow the user to change the ride height. The end result is a sleek lowered stance that provides improved handling to go along with its stunning visual appearance. The springs combined with progressive bump stops and other components increase travel that allows the car to be lowered up to a 1.25”. Suspension packers are included to fine tune handling and comfort by changing the clearance of the progressive bump-stops, something no respectable racecar is without. Components are machined from 6061-T6 aluminum and black anodized for appearance and corrosion protection.
Benefits of Dinan’s Performance Coil-Over Suspension System:
+ Threaded collars allow easy and precise front & rear vehicle height adjustments.
+ Up to 1 1/4” of lowering is possible depending on tire clearance although ¾” drop is
recommended to maintain ride quality.
+ Spring rates are 15% stiffer for both front and rear.
+ Substantial reduction in body roll.
+ Included suspension packers allow adjustment of bump-stop clearance to fine-tune
handling and comfort.
+ Dinan-spec progressive bump stops improve ride quality at lowered ride heights.
+ Components are machined from 6061-T6 aluminum and black anodized for a sporty
appearance as well as corrosion protection.
+ Compatible with BMW EDC shocks.
Tension Strut Ball Joint Kit for BMW F10 M5
The Dinan Tension Strut Ball Joint Kit provides responsiveness you can feel by replacing the rubber bushings in the thrust arms with precision ball joints and machined aluminum housings. Improves responsiveness by eliminating the deflection inherent in the stock rubber bushings while also reducing brake shimmy. The quietest bearings on the market are virtually noise free so you can live with them everyday. These are the only bearings on the market that are sealed using a rubber boot to keep out dirt and road grime stopping them from wearing out prematurely.
Benefits of the Dinan Tension Strut Ball Joint Kit for the F10 M5 & F06 F12 F13 M6:
+ Improved Steering Responsiveness
+ Reduces Brake Shimmy
+ Nylon-lined Bearings for Quiet Operation
+ Machined Aluminum Housings
+ Sealed Bearings
Dinan Lightweight Tubular Adjustable Anti-Roll Bar Set for BMW F10 M5
Almost all street cars come from the manufacturer with an anti-roll bar as it is a common part of modern suspension systems. However they are designed to be overly soft for maximum comfort. An anti-roll bar does exactly what it says by reducing body roll in all situations. Every Dinan tuned anti-roll bar is built and tuned specifically for each BMW chassis. Lowering the amount of body roll keeps your BMW more level than stock (while still allowing just enough body roll) to improve mechanical grip. This improvement gives the driver a much more planted and confident feeling in every corner. This Lightweight Tubular Adjustable Front Anti-Roll Bar may be added to the Stage 1 Suspension System for those who wish to build their high performance suspension in phases.
Front Anti-Roll Bar
Add a 28mm Lightweight Tubular Adjustable Front Anti-Roll Bar to reduce body roll, improve grip and stability while saving weight at the same time. The Lightweight Tubular Adjustable Front Anti-Roll Bar is 44% lighter than a solid anti-roll bar of comparable stiffness. This anti-roll bar is adjustable from 35% to 53% stiffer than the stock bar. This 2 hole bar can be mounted in 3 different positions with supplied end links that are left and right hand threaded for easy length adjustment.
Benefits:
+ Less Body Roll
+ More Mechanical Grip
+ More Stable At Limit
+ Large 28mm size (stock bar is 24.5mm)
+ 2 hole bar with 3 possible positions on bar & adjustable length end links
+ Lightweight – 44% lighter than a solid anti-roll bar of comparable stiffness
+ Only tubular anti-roll bar with a large range of adjustment on the market
+ Tubular (Hollow) Construction
Includes: Lightweight Tubular Adjustable Front Anti-Roll Bar, Urethane Bushings, Heavy Duty Brackets, Adjustable Length End Links.
Rear Anti-Roll Bar
Add a 22mm Lightweight Tubular Adjustable Rear Anti-Roll Bar to reduce body roll, improve grip and stability while saving weight at the same time. The Lightweight Tubular Adjustable Rear Anti-Roll Bar is 29% lighter than a solid anti-roll bar of comparable stiffness. This anti-roll bar is adjustable from 39% to 72% stiffer than the stock bar. This 3 hole bar can be mounted in 3 different positions with stock BMW end links.
Benefits:
+ Less Body Roll
+ Large 22mm size (stock bar is 21.5mm)
+ 3 hole bar with 3 possible positions on bar
+ Lightweight – 29% lighter than a solid anti-roll bar of comparable stiffness
Dinan Negative Camber Control Arms for BMW M5
Negative Camber Control Arms provide a reduction of understeer and more immediate turn-in from the M5 by inducing more negative camber on the front wheels. The additional negative camber improves the grip of the front tires in the turns thus reducing the vehicle's tendency to "plow" or "push" the front end for those who drive a bit more aggressively. This increase in negative camber is accomplished in two ways. The shorter front upper control arm increases camber gain, which is the amount of negative camber that is created by the geometry of the suspension as the car rolls to one side. In addition the static negative camber or the amount you will see on your alignment read out is also increased. The combination of static and dynamic camber gain adds an increase in front grip when the tire is loaded.
A quick look at your front tires will tell the story. If you are noticing significant outside edge front tire wear, perhaps even a bit of ''cupping'', you are definitely a candidate for the Negative Camber Control Arms. Not only will the extra camber improve the M6's handling, but you'll also likely notice more even tire wear, assuming you continue to corner aggressively.
Benefits:
+ Replaces front upper control arms with ones that increase negative camber by -0.3°
+ Improves grip of front tires
+ Evens out tire wear during aggressive cornering
      03-01-2017, 04:02 PM   #2
AutoTalent
AutoTalent's Avatar
2307
Bump!
      03-14-2017, 05:18 PM   #3
AutoTalent
AutoTalent's Avatar
2307
Bump!
      04-25-2017, 06:04 PM   #4
AutoTalent
AutoTalent's Avatar
2307
Bump!
      05-26-2017, 08:01 PM   #5
AutoTalent
AutoTalent's Avatar
2307
Memorial Day Sale until 9PM Pacific Time Monday. Feel free to PM or email as I will be checking constantly all weekend
      07-13-2017, 03:47 PM   #6
AutoTalent
AutoTalent's Avatar
2307
Bump!
      08-08-2017, 05:53 PM   #7
AutoTalent
AutoTalent's Avatar
2307
Let me know if anyone has any questions!
      10-12-2017, 03:34 PM   #8
AutoTalent
AutoTalent's Avatar
2307
Bump! PM today for special pricing!
      11-06-2017, 03:12 PM   #9
AutoTalent
AutoTalent's Avatar
2307
PM for a great deal
      12-21-2017, 07:26 PM   #10
AutoTalent
AutoTalent's Avatar
2307
Bump!
      12-27-2017, 01:33 PM   #11
AutoTalent
AutoTalent's Avatar
2307
Bump! Hope everyone had a great holiday!
      02-20-2018, 12:31 PM   #12
AutoTalent
AutoTalent's Avatar
2307
Bump!
      03-14-2018, 05:57 PM   #13
AutoTalent
AutoTalent's Avatar
2307
Bump!
      03-14-2018, 10:23 PM   #14
Housekeeping
Drives: 2013 BMW M5
I’ve got everything you’ve shown above on my F10, brilliant stuff!
      04-10-2018, 09:27 PM   #15
AutoTalent
AutoTalent's Avatar
2307
Definitely is. Hope you are enjoying it!
      05-14-2018, 09:03 PM   #16
AutoTalent
AutoTalent's Avatar
2307
Bump!
      06-26-2018, 05:33 PM   #17
AutoTalent
AutoTalent's Avatar
2307
Bump!
      06-29-2018, 08:54 PM   #18
Spinny02
Spinny02's Avatar
Pleas PM me price for the strut balls.
      06-29-2018, 10:54 PM   #19
Jeff W
Jeff W's Avatar
Drives: 2013 M5
Please PM me for price on Dinan coilover kit and install.
      06-30-2018, 10:04 AM   #20
xsilvor
xsilvor's Avatar
Drives: M5
Shouldn't this be in the Sponsored Classifieds?
The m3post forums are so much more organized
2015 F10 M5 DCT
2015 F82 M4 DCT (Sold)
2011 E92 M3 DCT (Sold) - Silverstone II.Black/Gray.Carbon/DINAN
2008 E92 M3 DCT (RIP) - Jet Black.Black.Carbon
Dinan, Wheels & Accessories for Sale
      06-30-2018, 01:36 PM   #21
WickedBMW
WickedBMW's Avatar
Drives: 2021 BMW M3 MT
I think they also have it in sponsor section as well
      07-23-2018, 05:28 PM   #22
AutoTalent
AutoTalent's Avatar
2307
Bump! Discounts codes are available, please visit our website or send us a direct message!
www.AutoTalent.com
