08-09-2018, 03:11 PM | #1 |
Rep 46
Methanol Injection
Is a JB4 necessary for proper meth setup or can a standalone ECU flash do the job?
FinanceNick stated that our ECUs can adapt and that a specific map for meth is not required either, just a few full WOT pulls and your good??? |
08-11-2018, 09:13 PM | #2 |
Rep 402
no way i would run meth that away, no built in safety when done that way. if you get a clog or any other trouble the motor would immediately run lean and then boom
08-12-2018, 03:10 AM | #3 |
Rep 46
financenick 11:11 AM 09-27-2017
Quote: Originally Posted by 3sgte View Post Sorry OP, this is OT. Which meth kit are you using? And is it a mapped meth kit, where meth flow is proportional to boost / revs, rather than one that just runs constant on a preset boost? I use AEM, and is not mapped for meth, our ecu's do a great job of working it out on their own, just needed 10 or so long 3rd gear pulls and she's good to go |
Mcc420475.00 |
08-13-2018, 09:20 PM | #4 | |
Rep 966
Skip the JB4 nonsense |
08-14-2018, 06:10 AM | #6 |
Rep 608
I'm using snow performance and it's super easy to set up. Just watch out for there customer service sucks.
F90 Comp, Hcp custom e40 meth, 9.76@143, 174ml/h 1/2ml 60-130 5.53 F10 M5, HCP Tune ,BM3, 10:8@137, 166.05 1/2ml. Ig @mcc420 |
08-14-2018, 09:37 AM | #7 |
Rep 489
Drives: E39 M5/ E30 325is
08-14-2018, 12:54 PM | #8 |
Rep 966
I have used snow performance in various installs.
Great products and the customer service is setup at a separate facility. Its easier to email for their customer service. It may take a day to get ahold of them but they do follow thru. |
08-14-2018, 05:44 PM | #9 |
Rep 232
Has anyone had good success using the BMS charge pipes with ports for methanol injection? I’d like know how effective it is for a water/methanol setup even though it wouldn’t be a true direct port setup. These high Texas temperatures take a toll on our motors.
08-17-2018, 07:17 AM | #10 | |
1087
Rep 1,968
So yes, any controller can work for our application with a flashes ECU unless you plan to run boost > 23psi and need a boost cut feature. |
08-20-2018, 04:33 AM | #12 |
1087
Rep 1,968
08-20-2018, 05:45 AM | #13 |
Rep 420
That’s impressive always thought there wasn’t much gains to be had unless tuning for it
So if you run meth and run out or get a clog and are not mapped for it everything will be safe? |
08-21-2018, 09:13 AM | #15 |
1087
Rep 1,968
If you tune for no meth (fuel or octane) then it should be fine. It’s when meth is used as a fuel source (> 23psi) and it gets clogged or something... kaboom!
08-21-2018, 04:09 PM | #17 |
Rep 232
100% H20, 50/50, or 80%H20/20 will all work great for cooling and cleaning benefits. My only gripe with my previous Direct Port Aquamist Methanol setup, was the nozzles would always clog. This was on another platform, but the concept is still the same.
08-21-2018, 08:15 PM | #19 | |
Rep 966
I have been buying from Snow Performance. Luckily I have not had that issue. I have used 50/50 and M1 What size nozzle do you use ? Last edited by schnell1982; 08-21-2018 at 10:00 PM.. |
08-22-2018, 06:11 AM | #20 | ||
Rep 608
08-24-2018, 04:55 PM | #21 |
Rep 2,062
Dumb question but how often do the nozzles clog and why? I've got a 55gal drum that I haven't touched yet, but if it's fresh from the drum and distilled/bottles water, what else could cause clogging?
08-24-2018, 05:12 PM | #22 |
Rep 232
